disc brakes 68 camaro? EXPERIMENT - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 21st, 09, 06:16 PM Thread Starter
Josh B
Question disc brakes 68 camaro? EXPERIMENT
My uncle owns a junkyard and I got a rear end from him out of a 03 1500 chevy truck 2wd. it still had the disc brakes on it. So I took to my garage where my 68 camaro is and I stripped the brake parts off the rear end. Looking at the rear end in my camaro it look like this will bolt right up perfectly if I could only find an identical rotor that is a 5-lug instead of the trucks 6-lug, and you cant drill the 6-lug, it won't work. please help! havent had time to try anything yet. THANX
j_Blanton34 is offline
post #2 of 3 (permalink) Old Jan 21st, 09, 08:06 PM
Larry
Re: disc brakes 68 camaro? EXPERIMENT
Do you have a good parts man??? Josh
I've taken hubs to mine an had him mick it and found new one that fit
and I also have re dilled rotor hats to fit other cars like phords
Good Luck
Larry
Larry B is offline
post #3 of 3 (permalink) Old Jan 21st, 09, 08:11 PM
Larry
Oh, one of the easy fit is from a s10 pickup
Larry B is offline
