Rear Suspension - Team Camaro Tech
post #1 of 20 (permalink) Old Jan 26th, 09, 11:16 AM Thread Starter
Rear Suspension
Can someone tell me the best way to raise the rearend of my 69? All I need is about an inch to keep the tires from rubbing when I hit a dip. The inside lip of the fender is bareley touching the tire on the sidewall of the tire where the tread starts and I really don't want to try rolling the edge of the fender. I was thinking some air shocks or a shackle kit but would like some good advice from the forum tech's if possible.
Thanks for any help you can provide.
Texasduece<br />"69" SS Clone
Texasduece is offline
post #2 of 20 (permalink) Old Jan 26th, 09, 11:46 AM
Steps
Re: Rear Suspension
I would be looking at :
Do the rims have the right off set?
Do the springs have the right arch and compression specs
Steptoe is offline
post #3 of 20 (permalink) Old Jan 26th, 09, 12:00 PM
BILL
SPARKY69's Avatar
Re: Rear Suspension
x 2
SPARKY69 is offline
post #4 of 20 (permalink) Old Jan 26th, 09, 12:08 PM
Fred
Re: Rear Suspension
And also do the tires look right? You know, are the wheel wells completely full? There is no better look than maxed-out meats. Seriously, there are few simpler, more reliable ways to solve a problem that you describe than stepping up to the plate with a baseball bat. I used a hacksaw and a portapower. Whew. That was work. Remember, back in the '70's people were radius-ing their wheel wells. Except for 69 Camaro owners. Then they invented mini tubs. Go with the bat.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 20 (permalink) Old Jan 26th, 09, 12:49 PM
tony
Re: Rear Suspension
i had my rear multileafs re-arched looks and works fine first tried a set of air shocks but made the ride verrry stiff and i was afraid of breaking the shock mounts.
juicen is offline
post #6 of 20 (permalink) Old Jan 26th, 09, 01:04 PM
Banned
Ron
Badbird's Avatar
Re: Rear Suspension
Air shocks would be OK as long as you keep them at 35-40 psi maximum, anything higher and your belly will be bouncing to the beat of the bumps in the road!....Also, a pair of load leveler shocks, with a 750 lb. load capacity, would be OK!
Badbird is offline
post #7 of 20 (permalink) Old Jan 26th, 09, 01:39 PM
Greg
Re: Rear Suspension
There are a lot of ways:
-re-arch existing springs
-get new springs
-Cal Trac allow for adding pre-load that raises the rear a bit
-Different offset wheels
-Smaller tires
I would stay away from air shocks if you can but they will work for sure.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #8 of 20 (permalink) Old Jan 26th, 09, 07:56 PM
Steps
Re: Rear Suspension
Back in the early n80s the orginal springs where a little flat and lost tension after over 100,000 miles and towing a med sized boat by the previous owner
So in the mean time I put in a set of air shocks...no pun intended but they where a pain in the butt
Got the springs re shaped and re torqued to top of factory spec. no more rubbing when going over a big bump with ppl in the back...the air shocks where then replaced....far better ride ...and I tow...biggest load was tare (weigh bridge) 1985 kg of gravel...no rubbing.
Steptoe is offline
post #9 of 20 (permalink) Old Jan 29th, 09, 07:59 PM
Re: Rear Suspension
If you have 4 leaf rear springs you could just add a leaf, it will raise the car up some as the other 4 leafs wont flatten as much, we used to do that at a shop I worked at in the late 80,s. If you have 5 leaf springs you can subsitute 1 leaf for a thicker and longer leaf, or 1 with more arc. Sometimes it takes a little trial and error.
Check your phone book and talk to a spring and suspension company. It is a lot easier to add 1 leaf than change the whole springs. IMO.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #10 of 20 (permalink) Old Jan 29th, 09, 08:14 PM
Banned
Re: Rear Suspension
I am a firm believer in adjustable coil-over shock helper springs b/c you can adjust them to wherever you want them AND they are CHEAP!!
It take's some time to pre-load them but once set, great by me!!
pdq67
post #11 of 20 (permalink) Old Jan 31st, 09, 12:43 PM Thread Starter
Re: Rear Suspension
Thanks for the input ya'll, I think I am going to get new springs or have the originals reworked. What is the hardest part of removing and reinstalling, are there anythings I need to be aware of before I start. In case you can't tell, I ain't never done this before (LOL) so it will be a leraning experience.
post #12 of 20 (permalink) Old Feb 1st, 09, 02:28 AM
Re: Rear Suspension
Hey Fred,
What wheel/tire combo are you running on your car, and do you have any other pics of them?
Lobstah is offline
post #13 of 20 (permalink) Old Feb 1st, 09, 10:46 AM
Re: Rear Suspension
My '68 mono leaf car came with coil over shocks. I was going to take them out before I drove it. It rides surprisingly well, so I left them.
go2fast is offline
post #14 of 20 (permalink) Old Feb 1st, 09, 10:56 AM
Steps
Re: Rear Suspension
Doing it with the fuel tank in
There is a post a thread about the time this one was started covering indetail how to and any issues that may arise
Steptoe is offline
post #15 of 20 (permalink) Old Feb 1st, 09, 11:15 AM
Re: Rear Suspension
I just changed some last week and the fuel tank was not a issue. IMO.
https://www.camaros.net/forums/showthread.php?t=149623
rszmjt is offline
