Rubber Washer on Spindle - Team Camaro Tech
post #1 of 12 (permalink) Old Jan 29th, 09, 03:25 PM Thread Starter
Shannon
Send a message via MSN to 67CamNKC Send a message via Yahoo to 67CamNKC
I stripped my spindles and noticed there was a rubber disc against the shoulder of the spindle on a drum brake setup. I am changing to discs and just noticed this washer. The parts house didn't have a listing for the washer. They seem to be OK. It would go against or near the wheel seal.
Should these be replaced or are they needed?
67 Camaro, Finally on the Rotisseri.....LSX?
67CamNKC is offline
post #2 of 12 (permalink) Old Jan 29th, 09, 03:56 PM
Re: Rubber Washer on Spindle
Shouldn't be a washer there..likely remnant of the inner grease seal.
68 coupe ,572,tko
Denvervet is offline
post #3 of 12 (permalink) Old Jan 29th, 09, 04:24 PM
Originally Posted by denvervet View Post
shouldn't be a washer there..likely remnant of the inner grease seal.
x 2
68 Camaro~LSx ~all motor
post #4 of 12 (permalink) Old Jan 29th, 09, 04:37 PM
My 67 has what seems like a leather washer on both spindles, I do beleive it is original as it was never apart before.
Harleyguy is offline
post #5 of 12 (permalink) Old Jan 29th, 09, 04:46 PM
Wayne
butternutz68's Avatar
http://www.rickscamaros.com/product....dept%5Fid=3506
Shannon,try this link ,backing plate seal.I was curious if they are needed on disc brake conversion.
work in progress
butternutz68 is offline
post #6 of 12 (permalink) Old Jan 29th, 09, 05:28 PM
NHBandit's Avatar
I have seen them on several disc brake cars that had never been apart. They do belong there although I doubt it would cause any problem at all if you left them out.
NHBandit is offline
post #7 of 12 (permalink) Old Jan 29th, 09, 08:07 PM
Banned
Smile Re: Rubber Washer on Spindle
You can use a washer cut from a writing tablet's cardboard backing if you are talking about the gasket between the dust shield for disc's or the drum backing plate and spindle fine.
Lightly oil/grease it up and go.
pdq67
post #8 of 12 (permalink) Old Jan 29th, 09, 08:42 PM
Jeff
yellow69RS's Avatar
X2
Jeff
yellow69RS is offline
post #9 of 12 (permalink) Old Jan 31st, 09, 09:05 AM Thread Starter
Shannon
Thanks guys. It does seem to be leather like instead of rubber.
67CamNKC is offline
post #10 of 12 (permalink) Old Jan 31st, 09, 11:51 AM
My 69 has front discs, and had leather washers like the ones in the Rick's link.
Jimb
Lobstah is offline
post #11 of 12 (permalink) Old Jan 31st, 09, 06:27 PM
David Pozzi
davidpozzi's Avatar
It's a cork gasket, may look different if soaked in brake fluid or grease. If you run dust shields on your disc brakes, it will prevent rattling. A little silicone seal will do it too.
davidpozzi is offline
post #12 of 12 (permalink) Old Feb 1st, 09, 03:17 AM
Dave,
I guess 40yrs of grease could make cork look like leather!
Lobstah is offline
