What PS Hose to Use? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 29th, 09, 06:10 PM Thread Starter
Clint
I just installed a AGR power steering box along with a 70s style saginaw power steering pump on my 69 coupe. Both the box and pump uses the male flared fittings. Can someone recommend what high pressure hose to use? Thanks.
Clint
cwb90 is offline
post #2 of 5 (permalink) Old Jan 29th, 09, 06:44 PM
Smile Re: What PS Hose to Use?
The stock '69 Camaro hose.
TJS69 is offline
post #3 of 5 (permalink) Old Jan 29th, 09, 07:47 PM
Ted
If his is like mine was he cannot use the stock 69 hose. The old style saginaw pump had a male fitting on it for the pressure side. The newer style saginaw pump has a female fitting. I got my hose from O'Reilly's. The numbers on the hose are AM091905 and 3317LE. I don't know what the specific application was to help you. You could have a custom hose place make you one also. I also have the AGR box and newer style saginaw pump.
tgifford5 is offline
post #4 of 5 (permalink) Old Jan 29th, 09, 08:49 PM
David Pozzi
davidpozzi's Avatar
If you need a hose with male fittings on each end, use a 1974 Nova pressure hose, the return should be the same for first gen Camaro or Nova. In 1974 Nova used the female pump outlet on the same subframe as a first gen Camaro.
OR there is a female to Male adapter available, then a stock 69 hose will fit.
I think the adapters are listed in this thread: https://www.camaros.net/forums/showthread.php?t=103139
davidpozzi is offline
post #5 of 5 (permalink) Old Feb 6th, 09, 09:25 AM Thread Starter
Clint
Thanks everyone for your help. Does anyone have a picture they can show of how the clamps go or how the cables are secured?
Clint
cwb90 is offline
