body mounts - Team Camaro Tech
post #1 of 9 (permalink) Old Jan 31st, 09, 05:44 PM Thread Starter
bernie
body mounts
Hi guys,
I have both radiator support mounts that need replacing where as the other four mounts I think are ok, see photo. Question should I just replace front two, will ride etc be affected, or just do them all and be done with it.
Cheers
Bernie
arfuso is offline
post #2 of 9 (permalink) Old Jan 31st, 09, 05:49 PM
Banned
Ron
Badbird's Avatar
Re: body mounts
Under the firewall and towards the ends of the subframe....As long as you can get them off, replace them all!
Badbird is offline
post #3 of 9 (permalink) Old Jan 31st, 09, 06:24 PM Thread Starter
bernie
Re: body mounts
Thanks Ron,
I thought so, but had to ask.
Bernie
arfuso is offline
post #4 of 9 (permalink) Old Feb 1st, 09, 10:16 AM
Banned
Ron
Badbird's Avatar
Re: body mounts
Originally Posted by arfuso View Post
Thanks Ron,
Bernie
You're Welcome!
Badbird is offline
post #5 of 9 (permalink) Old Feb 1st, 09, 10:43 AM
prostreet69camaro's Avatar
Re: body mounts
If your bushings are real bad it might mess with your door and front end gaps when you install the new ones. Look at your door to fender alignment gaps first then see how it looks when they are replaced.
prostreet69camaro is offline
post #6 of 9 (permalink) Old Feb 2nd, 09, 05:04 AM
1st 67 SS/RS's Avatar
Re: body mounts
Replace them all, but as past threads have mentioned, do one side at a time. Also, don't jack up the body to much when getting the new mounts in or getting the old ones out. I threw my front fender out of alignment by jacking it up to much.
67 Vert RS/SS 350 4 SP
1st 67 SS/RS is offline
post #7 of 9 (permalink) Old Feb 2nd, 09, 06:34 AM
Re: body mounts
Plus the steering shaft could get damaged.
blue ss is offline
post #8 of 9 (permalink) Old Feb 2nd, 09, 02:42 PM Thread Starter
bernie
Re: body mounts
I've ordered solid mounts from Rick's and have researched the forums and got good info on the install. Just need the mounts to co operate.
Thanks again guys.
Bernie
arfuso is offline
post #9 of 9 (permalink) Old Feb 2nd, 09, 02:58 PM
Doug
Re: body mounts
Not a hard job at all as long as the bolts come out without breaking the cage nuts. I just unbolted the steering box from the frame, removed the ground wires from the firewall, removed the front bumper brackets at the frame, and removed my passenger valve cover(so the cover would not hit the heater core). Then lowered the frame down about 3/4 inch and the bushings came right out. Hope that helps.
Dougs72Nova is offline
