Size of nut on spindle? - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 8th, 09, 07:04 AM Thread Starter
Ryan
Send a message via AIM to rp0029
OK so my car is stored far away from where I live. Last week I went to take off the front drums, but I didn't have a socket the size of the spindle nut, and it is torqued on there pretty good. I am going to stop by harbor freight.
What size is the spindle nut on the front of my 68 drum spindles?
Black 1968 Coupe.
Build thread
Modern, fuel injected LS engine DAILY DRIVER!
rp0029 is offline
post #2 of 5 (permalink) Old Feb 8th, 09, 07:17 AM
Re: Size of nut on spindle?
Never used a socket, channel lock pliers or vise grips always work for me. Vise grips are easier, just lock and roll. Be sure to remove the cotter pin.
Captain
Destin Fire
I'm sick and tired of mismanagement and disappointment. I'm a Cowboys fan
WYKOFF69Z is offline
post #3 of 5 (permalink) Old Feb 8th, 09, 07:40 AM Thread Starter
Ryan
What if the last guy used an impact gun to put them on? Will those methods work?
Black 1968 Coupe.
Build thread
rp0029 is offline
post #4 of 5 (permalink) Old Feb 8th, 09, 08:04 AM
Talking Re: Size of nut on spindle?
I don't think anyone would use an impact for this. You would crush your bearings. The spindle nut is usually not "tight". Tighten them up snug and then back them off so your cotter pin will go through.
TJS69 is offline
post #5 of 5 (permalink) Old Feb 8th, 09, 10:43 AM
David Pozzi
davidpozzi's Avatar
There is a cotter pin in there that may be hidden by the grease, remove it first.
davidpozzi is offline
