Global West Body Mount Bushings stock or 1/2 drop - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 10th, 09, 06:39 PM Thread Starter
Matt
Wanted to know if anyone has used 1/2 inch drop GW interloc body mount bushings instead of stock height ones that they offer as well? I am going with GW stage-3 suspension package and have a choice of stock height or 1/2 inch drop body mount bushings. The package includes springs that will drop the front-end 1 inch. Backend will drop a little over 1 inch using their leaf springs. I am leaning towards the 1/2 inch drop bushings as this will lower the body a bit more without taking away from the suspension travel. Any issues with header scrapes?
Thanks.
Matt
zlek131 is offline
post #2 of 4 (permalink) Old Feb 10th, 09, 10:05 PM
SS
Re: Global West Body Mount Bushings stock or 1/2 drop
I heard the dropped versions can make the crossmember a PITA!
I have the standard thickness and they are nice pieces.
SS
406, TKO 600 and 12 bolt posi.
railing68 is offline
post #3 of 4 (permalink) Old Feb 11th, 09, 06:54 PM
67 Camaros Rock
Joe Harrison's Avatar
SS
They can also affect hood clearance and firewall clearance. All our Camaros are different but becareful here. I have read on other sites the PITA factor in some areas was not worth any gain unless your a building a track car.
I have the solids made by CE and they are excellent, I will never put on rubber or poly again. I hated the poly, they sqeeked all the time!! The solids have worked very well for 6 years and over 70,000 miles!! No ill affects from them.
-Mark Donahue
My 67 Camaro Time Line
Joe Harrison is offline
post #4 of 4 (permalink) Old Feb 12th, 09, 08:50 AM Thread Starter
Matt
Thank you all for the good advise. I will stick with standard height.
Matt
zlek131 is offline
Tags
1/2 inch, body mount bushings, drop, global west, interloc
