Dazed and Confused on springs - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 12th, 09, 10:07 PM Thread Starter
Shawn
Have done a lot of reading on this site as to what rear spring to run. I'm in the process of converting the car to disc brakes and figured while I was at it do the springs. I want to raise the car as it sits to low (floor to rocker panel front 8", rear 10"). I ordered big block springs for the front. I'm not sure whether to go with a 3,4 or 5 spring leaf. Sounds like 5 leaf would raise it enough but I don't want the ride to suck. Suggestions???
Shawn67RS is offline
post #2 of 4 (permalink) Old Feb 12th, 09, 10:44 PM
Banned
Re: Dazed and Confused on springs
Shawn,
Do this!!
Install the cheap roundy-round adjustable cans in front and then pick what rate short roundy-round coil spring you want to run!
Then in the rear I would go w/ stock mono's and cheap coil-overload shock springs and I did for years.
You will just need to tune them is all height-wise and side to side rear tire pre-load and go!
And I love my old homemade "slapper" traction bars too! And they are cheap enough so I didn't spend $100's on whatever the latest and greatest modern "slappers" are cost-wise..
Just make sure that they slap right under the front spring eye!!!!!!!!!!!!
NOT on the leaf before b/c they can twist and break them!!!!
pdq67
post #3 of 4 (permalink) Old Feb 12th, 09, 10:46 PM
Banned
Angry Re: Dazed and Confused on springs
Sucker is feeding back to somebody too F** slow!
pdq67
post #4 of 4 (permalink) Old Feb 13th, 09, 10:25 AM Thread Starter
Shawn
Thanks pdq, sorry I went to bed after I posted. Already started install of big block springs. Makes sense using coil overs. Used front spring inserts and air shocks on the one I had back in high school, didn't know if there was a better way 25 years later.
