Body bushings question - Team Camaro Tech
post #1 of 15 (permalink) Old Feb 15th, 09, 07:30 PM Thread Starter
Louie
rad454's Avatar
Has anyone here installed new body bushings and noticed the hole is about
twice the size of the bolt that goes through it into the body? What gives here. There seems to be
way too much slop for this to be correct.
rad454 is offline
post #2 of 15 (permalink) Old Feb 15th, 09, 07:44 PM
Send a message via AIM to RamAirDave
Re: Body bushings question
The "slop" is there to give room to align the subframe to the body
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #3 of 15 (permalink) Old Feb 15th, 09, 07:53 PM
"Tri-Tip"
Gary L's Avatar
I replaced one lower with a new part because the first part deformed out from under the washer. Both were GM parts. The first part was all rubber. The second had steel reinforcement. Did the originals have the steel?
Gary L is offline
post #4 of 15 (permalink) Old Feb 15th, 09, 07:56 PM
yeah, the originals had the steel washer built in.
post #5 of 15 (permalink) Old Feb 16th, 09, 01:30 PM
"Tri-Tip"
Gary L's Avatar
For 1967 to early 1969 model year the lower body cushion was the same front and rear. Early 1969 the front stayed the same and the rears changed. What changed? Do only the rears have the embeded washer. The washer goes against the body, correct?
Gary L is offline
post #6 of 15 (permalink) Old Feb 16th, 09, 01:58 PM
Craig
Brackneyc's Avatar
When I changed all of mine, they were all wood. Yes, some joker put wood doughnuts in there.
Craig
Now you will see that evil will triumph, because good is dumb.
-Dark Helmet
1967 Camaro
1965 Mustang
2007 Mustang
Brackneyc is offline
post #7 of 15 (permalink) Old Feb 16th, 09, 02:09 PM
"Tri-Tip"
Gary L's Avatar
Thanks for the help!
I guess the guy wanted solid bushings.
Gary L is offline
post #8 of 15 (permalink) Old Feb 16th, 09, 04:19 PM
Fred
These are my originals that I replaced last summer with aluminum. My car is a May build. The rears are the larger set.
128.79mph 1.428 60'
Fred Ficarra is offline
post #9 of 15 (permalink) Old Feb 16th, 09, 07:22 PM
"Tri-Tip"
Gary L's Avatar
Fred, do the ones that have the 4802 part number have molded in washers or are they all rubber?
Does anyone sell the original looking grade 8 bolts and washers? AMK bolts aren't right.
Gary L is offline
post #10 of 15 (permalink) Old Feb 16th, 09, 08:34 PM
They all have the metal sleeves/washers (from the factory).
I think the OER bushing set is the one Ive used on a few cars in the past, and they have the AIM-corresponding PNs on them so you know where they all go.
post #11 of 15 (permalink) Old Feb 17th, 09, 06:00 AM
"Tri-Tip"
Gary L's Avatar
RAD, I know the top cushions have metal sleeves and washers, but I am thinking the lower front cushions don't have a washer molded in. The AIM calls the front and rears different part numbers. I bought Chevrolet part number 3914802 and they are all rubber. That part is baffling.
Gary L is offline
post #12 of 15 (permalink) Old Feb 17th, 09, 09:14 AM
Lower cushions did not have the washer molded in. My car has never had them changed and I have had the lowers off to take out the trans crossmember. The uppers still have masking? tape around them from the Norwood Plant. FWIW.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #13 of 15 (permalink) Old Feb 17th, 09, 12:00 PM
Fred
Gary, one of my original bolts is to the right in this picture. It's coned at the tip for one reason: assembly line power tool speed wrench installation. You don't need it.
128.79mph 1.428 60'
post #14 of 15 (permalink) Old Feb 17th, 09, 12:22 PM
"Tri-Tip"
Gary L's Avatar
Fred, do the rubber cushions with the 3914802 number molded in have metal washers molded into them?
Gary L is offline
post #15 of 15 (permalink) Old Feb 17th, 09, 05:19 PM
The small lower cushions do not have metal.
