Hydroboost Pushrod length - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 16th, 09, 01:13 PM Thread Starter
Jereme
Hello,
I have the following set up:
Mid 90's Astrovan HB, rebuilt from a guy on ebay. He provided 2 threaded brake pedal push rods, I am using the short one and the top hole in the pedal.
Nick Diprenda's mounting bracket
69 Corvette Manual Brake MC
C4 brakes in front
95 Camaro 11" brakes in rear
Having a tough time bleeding brakes. Have been using a combination of :
my girlfriend on the brake pedal conventional bleeding. Did not work...
AC style vacuum pump to evac line. Marginal success.
Mity-Vac - Best so far. Fluid to all wheels, but can't seem to clear all of the air.
Even after I got fluid to all wheels, I have not been able to get any resistance at the pedal or any brake pad movement. So I have begun investigating pushrod length more carefully. The Corvette MC should use the long pushrod. The cavity in the MC measures 1.655" deep, this should equate to needing the long pushrod which from what I have learned in this forum should be 4" long. I pulled the pushrod from the HB and it measures 3.14" One final point of reference is that when I push on the brake pedal I only see fluid movement in the front circuit of the MC.
I have read that these Corvette MC's are tough to bleed for some reason, so my current plan of attack is to install a 4" pushrod and coax my girl back over to press on the pedal. Any reason I should not go to the longer pushrod?
Thanks,
Jereme
1969 L78 SS396 (Engine Long Gone)
BBC 496, TKO600, Beautiful Stock 12 Bolt Posi (maybe the only stock thing left.
RedJet is offline
post #2 of 9 (permalink) Old Feb 16th, 09, 03:13 PM
EY
Re: Hydroboost Pushrod length
I just bought a MC for a later ~79 ('sh) vette it has the shallow hole pushrod piston for my HB unit. I thought I needed a MC from ~70 C3 but found out about the pushrod legths before I bought it, hence the ~79 model.
I believe you could fab a "spacer" or change to a long style pushrod also. Check Pozziracing.com
With the deep hole and short pushrod it wont work.
E.Y. Finland,
-67 RS
Orig: PG + 327/275 + 12-bolt.
Now: SBC409 TKO600
rodek is offline
post #3 of 9 (permalink) Old Feb 16th, 09, 07:20 PM Thread Starter
Jereme
Thx for the repy E.Y.!
I have checked out David's website and fabed up a 4" pushrod. I am now working on a banjo bolt leak on my rear caliper. Still no luck with the girlfriend... Maybe a bottle of wine will put her over the top I will keep you posted.
Best,
Jereme
RedJet is offline
post #4 of 9 (permalink) Old Feb 16th, 09, 10:45 PM
Fred
Jer! Why didn't you call me?!! Not that I could help from here. And the camper is washed because it's going to the dealer for fabric change-out tomorrow. That means I'm tied up for a couple days. That and Jacque is coming over Thursday with the kids so I can R&R her truck. Maybe this weekend? Note to readers; We're family.
128.79mph 1.428 60'
Fred Ficarra is offline
post #5 of 9 (permalink) Old Feb 16th, 09, 10:50 PM
Jereme - who recommended that MC? Not sure you'll be happy with it. I think it's a 1" bore. You'll likely get a lot of pedal travel with it. I'm using a 1 1/8" bore 69 Camaro disc/drum MC with hydroboost on a very similar system at the recommendation of Hydratech and it's dead nuts perfect.
BPOS is offline
post #6 of 9 (permalink) Old Feb 16th, 09, 11:29 PM Thread Starter
Jereme
Fred -- come on down! I can always use labor that is smarter than myself!
Al - I kinda picked it on a lark, based on what I was expecting from the hydroboost. I was also considering port location and compatibilty, maybe I picked a less than optimal, we shall see!
Hey if Fred comes down this weekend maybe we can get together and check out your car? Is it still in the couve? Let me know....
BTW- I have a rotten-stinkin-leak on my RH rear caliper that is frustrating me! Had to walk out of the garage tonight to get my sanity back...Ugh!
Best,
Jereme
RedJet is offline
post #7 of 9 (permalink) Old Feb 17th, 09, 10:21 AM
Fred
Jer, I'll keep ya posted,,,
128.79mph 1.428 60'
post #8 of 9 (permalink) Old Feb 17th, 09, 02:09 PM
EY
Just to let you know here are the P/N's for raybestor master cylinders.
So these are for the C3 corvette and they "look correct" (almost) if you are duplicating period correct disc brakes (JL8). Both of these mc's were originally for a power brake corvette so they are equipped with a 1 1/8 piston bore. The only difference is the pushrod hole, it's either deep or shallow.
MC39018 CHEVROLET CORVETTE (1967 - 1976) (+many others!!)
{Professional Grade Bore Size=1 1/8" Number of Ports=2 Primary Outlet Size=1/2x20 Secondary Outlet Size=9/16x18}
Power Brakes
DEEP HOLE FOR LONG PUSHROD HERE
MC39052 CHEVROLET CORVETTE (1977 - 1982) (ONLY!!)
Power brakes
SHALLOW HOLE FOR SHORT PUSHROD HERE
E.Y. Finland,
-67 RS
Now: SBC409 TKO600
rodek is offline
post #9 of 9 (permalink) Old Feb 17th, 09, 02:11 PM
Best,
Jereme
Still in the 'couve! PM me.....
BPOS is offline
