Bushings in general - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 17th, 09, 09:28 AM Thread Starter
Jan
Bushings in general
Will not take long now before i can start changing bushings in the front. But - has anyone ever bought a complete set of bushings from e.g NPD? Can you suggest any good supplier of poly graphite bushings?
Planning on lowering the front about 1". Anything special to think about in regards to bushings etc.?
67 Swedish Convertible
67 Swedish Convertible is offline
post #2 of 7 (permalink) Old Feb 17th, 09, 12:05 PM
Fred
Re: Bushings in general
I went with David Pozzi's advice. No good reason to use anything except solid aluminum.
128.79mph 1.428 60'
Fred Ficarra is offline
post #3 of 7 (permalink) Old Feb 17th, 09, 01:16 PM
Fred
77thor's Avatar
If you want polygraphite bushings.........
I have purchased from http://www.p-s-t.com/ for my 77 Camaro...
just make sure to lube them up very well before installing...
77thor is offline
post #4 of 7 (permalink) Old Feb 17th, 09, 01:20 PM
Arch Stanton's Avatar
I just finished doing the upper and lower A arms on the front suspension. I used Energy Suspension's polygraphite (black) bushings. Definite improvement over the stock worn out sloppy rubber bushings.
My only suggestion is if you use the poly bushings, order an extra few tubes or extra "lube" they send. Follow the directions exactly, and don't be afraid of using the lube. I noticed a squeak before I tightened the lower a arm bolts, stopped, put lube on the bushings and where the A arm goes onto the frame, no more squeak.
Been driving it around, not a squeak.
Hope that helps.....
PST bushings I'm sure are just as good as Energy Suspension.....I have their sway bar end link kit. Good stuff.
- John
Misfit tortured soul. Lone wolf. Unicorn.
'67 V8 Camaro - 12637, 797-Z (Parchment), M-M (Royal Plum), 2M, 3K, 5Y
Arch Stanton is offline
post #5 of 7 (permalink) Old Feb 17th, 09, 06:13 PM
I used Energy Suspension graphite bushings and wished I hadn't. I used plenty of lube during installation, but after 10,000 mile they squeak bad. It's very embarrassing to drive, the slightest bump causes squeaking. Everyone claims better handling but where's the proof? If you like a harsh squeaky ride go with poly, if you want parts that designed to work go with OEM rubber.
67maro
67maro is offline
post #6 of 7 (permalink) Old Feb 17th, 09, 11:08 PM Thread Starter
Jan
Thanks for that info guys,
Is there really a big need for putting extra lube on there? I was under the impression that the graphite worked as a lubricant and extra lube, or lube in general, was not needed?
Pure polyurethane bushings (not poly-graphite), however, was the "squeeky sort". Or am I wrong?
I do want a solid car with good handling. I do not want to the squeeks.
Anyone else that picked OEM rubber like 67maro?
post #7 of 7 (permalink) Old Feb 18th, 09, 02:32 AM
i used stock replacement Moog bushings in my Nova, and it worked fine for me..
i don't know how much bind there was compared to poly or solids or delrins, but i was able to move the suspension up and down by grabbing onto the spindles with the bolts all tightened up but no springs in it. it was stiff, but it did move.
you don't plan sincerity.
novaderrik is offline
