brakes jerk left - Team Camaro Tech
post #1 of 17 (permalink) Old Feb 17th, 09, 12:26 PM Thread Starter
gregg
brakes jerk left
I replaced the front wheel cylinders on my 69 convert. I also put a new drum on the pass. side along with new pads all around. When I apply the brakes, the car jerks left then pulls right. Do I need to adjust the pads, turn down the old drum? What could cause this??
gemstick is offline
post #2 of 17 (permalink) Old Feb 17th, 09, 12:56 PM
Re: brakes jerk left
Yes all of the above, also did you clean the new drum, any grease prints on the shoes
can cause pulling, or grabbing.
john68 is offline
post #3 of 17 (permalink) Old Feb 17th, 09, 01:49 PM
BILL
SPARKY69's Avatar
sounds like your brake adjustment is off...I WOULD TURN YOUR OTHER DRUM ALSO ,IT PROBALLY HAS A RIDGE ON IT AND IS GLAZED OVER ...YOU WANT A SLIGHT DRAG ON YOUR DRUMS AS YOU TURN THEM BY HAND, NOT TIGHT, BUT NOT LOOSE, JUST ENOUGH TO HEAR THE DRUM AND SHOE BARELY CONTACTING..ONE OTHER WAY TO SET THE CORRECT ADJUSTMENT THAT A LOT OF PEOPLE DO IS ADJUST YOUR ADJUSTER TIGHT SO YOU CANT SPIN THE DRUMS BY HAND AND THEN BACK THEM OFF TILL THEY HAVE A SLIGHT DRAG..
SPARKY69 is offline
post #4 of 17 (permalink) Old Feb 17th, 09, 05:08 PM
If the rubber flex lines go bad they can cause this situation also.
hogshooter is offline
post #5 of 17 (permalink) Old Feb 17th, 09, 07:03 PM
Jeff
yellow69RS's Avatar
I would replace the other drum. In class they told us to turn both of the drums to the same diameter, seems pointless to turn a new drum out to match a used one. I'd check the front suspesion parts for looseness as well.
Jeff
yellow69RS is offline
post #6 of 17 (permalink) Old Feb 17th, 09, 07:15 PM
Larry
this happen to me twice
Larry
Larry B is offline
post #7 of 17 (permalink) Old Feb 19th, 09, 02:48 AM Thread Starter
gregg
I ordered a new drum, will get it on this weekend. I have a good mechanic set up to do a PA state inspection on CUPCAKE (named after my dad). Since I am a novice backyard mechanic and the brakes are a pretty important safety factor, I am asking him to check them out for me as well!!
THANKS
gemstick is offline
post #8 of 17 (permalink) Old Feb 19th, 09, 03:41 AM
x 3 on replacing the rubber flex lines. They may look fine on the outside, but be swollen shut on the inside. Before you replaced the brakes, it may be that everything wasn't working well at all, and now some of it working correctly and some not. If you readjust and still have issues, look at replacing the hoses.
Dodging all the buggies around Ship is hard enough without flaky brakes.
Eric
Eric Kammerer is offline
post #9 of 17 (permalink) Old Feb 19th, 09, 04:45 AM
Since you have replaced the ft cylinders you could also have a lil air that needs to come out still.
blue ss is offline
post #10 of 17 (permalink) Old Feb 19th, 09, 04:47 AM
BILL
SPARKY69's Avatar
The hoses are a cheap and good idea to replace only 19.99 a hose..like everybody said you cant tell if they are swollen on the inside or not!
SPARKY69 is offline
post #11 of 17 (permalink) Old Feb 24th, 09, 07:15 AM Thread Starter
gregg
okay I replaced the drum, bought new hoses, but I'll be DANGED if I can break the brake lines free from the rubber hoses. ANY ideas on what I can do to get them free?? I used a line wrench, WD40 and still have the fittings "sorta" rounded off. Oh while taking for a test drive, the shifter cable broke, that question is in the transmission forum!!
R we havin fun yet..... YOU BET!!!
gemstick is offline
post #12 of 17 (permalink) Old Feb 24th, 09, 07:17 AM
BILL
SPARKY69's Avatar
vise grips baby!!!!!!!!!!!!!!!!!!!!!!
SPARKY69 is offline
post #13 of 17 (permalink) Old Feb 25th, 09, 02:37 AM Thread Starter
gregg
vise grips and WD40 did the trick on the rear, I changed the rear wheel cylinders last night. I will probably try the good ole vise grips on the front as well!!
THANKS FOR ALL THE HELP!! I don't knowif the leaking wheel cylinder fixed the "jerk left" yet because I still haven't changed out the shifter cable.
gemstick is offline
post #14 of 17 (permalink) Old Feb 25th, 09, 03:46 AM
BILL
SPARKY69's Avatar
keep us posted!!!!!!!!!!!!
SPARKY69 is offline
post #15 of 17 (permalink) Old Feb 25th, 09, 03:49 AM
Change the brake hoses B 4 U spend any more time or money on the other stuff!
Mostly Camaros and FINALLY a Double Nickel
Yellow69RSZ is offline
