Lower spring plate - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 17th, 09, 09:37 PM Thread Starter
bernie
Lower spring plate
Hey Guys,
I need to remove my traction bars to register my car and order from the US lower spring plates for my '67. I believe the rear is not original rear axle code BM 0314G2 indicates '68 or '69.
I took photos to show the set up. Can you advise what plates I need, retaining the multi leaf set up. I'll probably order from Rick's.
Bernie
URL=http://imageshack.us][/url]
arfuso is offline
post #2 of 13 (permalink) Old Feb 18th, 09, 01:26 PM Thread Starter
bernie
Re: Lower spring plate
As the shocks are not staggered I will order lower plates for a '68/69. Any preferences to who?
Bernie
arfuso is offline
post #3 of 13 (permalink) Old Feb 18th, 09, 01:37 PM
prostreet69camaro's Avatar
68/69 camaros have staggered shocks. You need to ones for a 67. Ricks has them
Part # SS-48
Part # SS-47
or if you want the DSE lower plates
DS-29
http://www.rickscamaros.com/find.asp?
prostreet69camaro is offline
post #4 of 13 (permalink) Old Feb 18th, 09, 01:39 PM Thread Starter
bernie
Thanks Mike
Bernie
arfuso is offline
post #5 of 13 (permalink) Old Feb 20th, 09, 12:38 PM
Banned
You mean to tell us that they won't license your car w/ traction aids installed??
If so, this suck's!
pdq67
post #6 of 13 (permalink) Old Feb 20th, 09, 07:46 PM Thread Starter
bernie
If so, this suck's!
pdq67
Nope. They sit below the rims and have to go. I'm a bit confused.
Can you answer this for me. Looking at the shots of the 67 rear axle I have non staggered shocks and multi leaf springs. Must I order as prostreet 69 Camaro suggests lower plate for 67 OR 68/69 plate for multi leaf.
Bernie
arfuso is offline
post #7 of 13 (permalink) Old Feb 21st, 09, 05:47 AM
Banned
Right, it's the Law that nothing can be below a flat tire b/c then it can drag and either tear the road up or get caught and really screw things up, like flip you..
Get the '67 shock plates, they are like your hands!! A right side and a left side!
Not just one that is rotated front and rear like the '68/'69's do.
pdq67
post #8 of 13 (permalink) Old Feb 21st, 09, 07:03 AM
T
As mentioned, you're going to need "67" plates in order to have the correct shock mount location on the lower spring plates -- the 68/69 plate for the LH side would have no way to mount your shock!
AFAIK, there were never any multi-leafs installed in '67 camaros from the factory, and since multi-leaf and mono-leaf shock plates are different, there's no such thing as a "stock" multi-leaf spring plate for a '67. Check out David Pozzi's site for info, but I think (?) it's just the height of the shock location and metal thickness that's different:
http://www.pozziracing.com/rear_suspension.htm
So Rick's has good stuff, but those part numbers listed are for stock-type mono plates
Seeing has you're probably going to drop some $$ on shipping to Oz anyway, I'd vote to get the beefier stuff from Detroit Speed & Engineering (stock type, non-staggered, shocks outboard):
http://www.detroitspeed.com/productp..._prod_test.htm
TMessick is offline
post #9 of 13 (permalink) Old Feb 21st, 09, 10:55 AM
Sorry but there are 2 differents sets of numbers in Ricks catalog. The second set are the DSE plates for 74.99 a set. Part# DS-29
post #10 of 13 (permalink) Old Feb 21st, 09, 04:12 PM
Banned
I just looked again, trim your "J"-bolts back CLOSE and use thinner locking nuts and tell them to KYA b/c they aren't below your rims lips!!
pdq67
post #11 of 13 (permalink) Old Feb 21st, 09, 04:22 PM
pdq67
I Agree, or just take off the J-Bolts and use original U bolts only. The J bolts dont help much anyway IMO.
2002 Jerry Bickle Cavalier, 446" Small Block, Brodix Canted Valve, lenco 5 speed, 7.54 @ 180. mph,1.06 60', 2235 lbs for 2014. GM Canada Docs, Highly Optioned 69 RSZ28 , Hugger Orange, White Stripes, 42,000 mile survivor, owned since 1973.
rszmjt is offline
post #12 of 13 (permalink) Old Feb 21st, 09, 04:31 PM Thread Starter
bernie
pdq67
I will sus out using U bolts and thinner nuts, not sure about the KMA (LOL)as I don't need to b on the wrong side of the licensing guys.
Thanks again
arfuso is offline
post #13 of 13 (permalink) Old Feb 21st, 09, 07:43 PM
T
I never was very good at reading and following directions.... Somehow I missed that you posted the DSE part number there. My bad.
Anyhow, SS-48 & SS-47 from rick's are for the monoleaf setup.
DS-29 is the DSE plates for non-staggered shocks and would be my choice if you're going to replace the plates.
TMessick is offline
