which brake lines - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 17th, 09, 10:47 PM Thread Starter
Viktor
yevgenievich's Avatar
Send a message via AIM to yevgenievich
which brake lines
i got a set of disk brakes to replace front drums on 67 camaro. It's a kit with spindles. The flex hose is damaged on the car and i need new one for the right and left sides. i checked on ground up and they had 3 different kinds and i got confused on which one to get. Any help appriciated
1992 dodge stealth, base
1989 firebird T/A, ls1/t56
1967 Camaro
1991 V2500 Suburban
yevgenievich is offline
post #2 of 9 (permalink) Old Feb 19th, 09, 08:40 PM Thread Starter
Viktor
Re: which brake lines
any idea which hose would i need?
1967 Camaro
1991 V2500 Suburban
post #3 of 9 (permalink) Old May 5th, 09, 06:58 PM Thread Starter
Viktor
ok, back to the top. I still need to figure out if i need replacement hoses that originally were made for car with disk brakes or get a set that was made for drum brakes?
1967 Camaro
1991 V2500 Suburban
post #4 of 9 (permalink) Old May 5th, 09, 07:38 PM
Dan
Drum brake hoses will not work, I used a front disk configuration from a stock 69 camaro setup on my 68 coupe. Those hoses should be readily available at your local auto parts store
68 camaro RS 327/275 THM350 4 wheel disc brake 8.5 10 bolt 3.42 daily driver
icpop is offline
post #5 of 9 (permalink) Old May 5th, 09, 07:39 PM
Ed
BigBlock1969RS's Avatar
You might check out The Right Stuff Detailing:
http://www.getdiscbrakes.com/Default.aspx
They make a lot of the brake lines that the Camaro restoration parts houses sell. You could probably call them and they could suggest something. I bought all my lines from them dealt with Bear, he could set you up.
Ed
BigBlock1969RS is offline
post #6 of 9 (permalink) Old May 6th, 09, 09:39 AM
keypilot's Avatar
dan is right you will need disk brake hoses. you can get them at any local parts store. the application will be 67-69 front disk brake hose. all the same.
Don't stop now!!!
67 camaro driver
383 10:1
Horsepower:
515 @ 5,500 rpm
Torque:
499 lb-ft @ 4,800 rpm
keypilot is offline
post #7 of 9 (permalink) Old May 7th, 09, 02:46 PM
Bill
I have a question about the brake lines, I have a 68 Camaro, but I believe the rotors and calipers are from a 72 Nova, the brake hose for a 69 Camaro with discs is different than the Nova one, and the price is half, which one is right?
GasserOhio is offline
post #8 of 9 (permalink) Old May 7th, 09, 08:49 PM
Steiner
It is going to depend on which brake kit you have. I think the stock ones might screw directly into the calipers. If you have an aftermarket set that uses newer calipers that have been machined at the fitting, you may want to go with a line that uses a banjo fitting. That's how mine from Matt's (Right Stuff) are set up but I have the braided lines. You have to know if your caliper has an NPT reducing hole or just a through hole.
'69 Camaro
500hp/538lbft
Steiner is offline
post #9 of 9 (permalink) Old May 9th, 09, 08:39 PM Thread Starter
Viktor
stock disk brake hose didn't work
I got wilwood calipers and the hole for the hose to thread into is smaller. I guess i need to call them up and find out what hose to run.
edit: little more searching and found a kit from wilwood. They have few different options, not sure which one i would need
http://info.wilwood.com/LineKitsProd....75%22%20rotor
1967 Camaro
1991 V2500 Suburban
