car vibrates bad at around 55 mph help! - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 19th, 09, 01:30 AM Thread Starter
Robert
I have a 1980 camaro with 14inch ss craigers. I owned this car 8years ago and sold it becouse of a devoirce. recently bought it back. drove good 8 years ago. only change the other guy made was new tires and airshocks on back. I just bought new tires again for it and center link,inner tie rods, pit arm. and front end alignment. still getting a vibration like crazy at 55 or so. any ideas to check out right off hand?
srobertlaw2003 is offline
post #2 of 13 (permalink) Old Feb 19th, 09, 02:09 AM
mark
Re: car vibrates bad at around 55 mph help!
Most likely is a tire out of balance. Do you feel the vibration through the steering wheel or is it the whole car is shaking. Point being if it is strong feeling in the steering wheel it will probably be one of the front tires. If not the tires the smart guys here will help you out. mark
stroud6 is offline
post #3 of 13 (permalink) Old Feb 19th, 09, 02:16 AM Thread Starter
Robert
well it feels like the vibration is comin from front end. noticed the tread on the inside of the front tires seems to be wearing some. wouldnt think the about of wear im seeing would cause it to vibrate so much. it almost shakes to bad to drive over 55mph.
post #4 of 13 (permalink) Old Feb 19th, 09, 04:11 AM
BILL
SPARKY69's Avatar
Check all your frnt end, susp(ball joints......) make sure you dont have a bent rim, shifted belt in your tire....
SPARKY69 is offline
post #5 of 13 (permalink) Old Feb 19th, 09, 06:43 AM
BonzoHansen's Avatar
What is vibrating, the steering wheel? The seat/floor?
http://www.tirerack.com/images/tires/vibechart.pdf
TC Member #13
BonzoHansen is offline
post #6 of 13 (permalink) Old Feb 20th, 09, 12:05 AM Thread Starter
Robert
the whole car is vibrating,seats windows t-tops, but no vibrating at steering wheel, it seems normal. im running 14inch ss old style craigers new tires on back old tires with about 45% tread let. notice the wheels had nuts being used a lug nuts on half the wheels. just had center link,inner tie rods replaced. and front end aligned.
post #7 of 13 (permalink) Old Feb 20th, 09, 12:11 AM
Art
If they are the "unilug" style, this is most likely the source of your vibration and can be very unsafe. Replace the lugs(and spacers if necessary) with the proper hardware before trying anything else, I wouldn't even drive the car like that.
Artie
67 Camaro
99 T/A Daily Driver
Previous:
67 Camaro Traded for my 98
68 Camaro Street/Strip
98 Camaro Race car Best ET 9.08 @ 152 1.18 60'
Dyno sheets don't win races, see you at the track
SRGN is offline
post #8 of 13 (permalink) Old Feb 20th, 09, 12:49 AM Thread Starter
Robert
hmm I owned this car about 8years ago lost it in a devoirce. found it again 2 weeks ago bought it on the spot. it had same craigers on it when I owed it before and car drove like a dream. but I had corret lug nuts on it and not shure about spacers? i noticed the rear wheels are sitting flush up against the drums? is thats normal? I mean rigt up against them.
just got off the craiger site. noticed is said that length mag style lugs must be used with these wheels. so maybe it is the lugs causing it. half the lugs are just plain nuts not lug nuts.
post #9 of 13 (permalink) Old Feb 20th, 09, 05:34 AM Thread Starter
Robert
well just got off work and went home to check which wheels didnt have proper lugs and the front wheels all have right one's. but passenger side rear only has 2 of the right lugs the other 3 are just plain nuts. and driver side has all the right lugs but one. could this cause my vibrating problem?
post #10 of 13 (permalink) Old Feb 20th, 09, 06:15 AM
You might want to check drive shaft and u joints too.
Stainless dog is offline
post #11 of 13 (permalink) Old Feb 20th, 09, 06:43 AM
Ted
Robert are you getting vibration from the front or not? One thread says vibration coming from the front and another says no vibrating at the steering wheel. Stainless has a good point. Maybe wheel bearings are going out. I have read other posts regarding the unilug wheels as Art has said - unsafe. Can you get your hand on a stock set of wheels/tires? That might eliminate if it's the craigers.
tgifford5 is offline
post #12 of 13 (permalink) Old Feb 20th, 09, 05:13 PM Thread Starter
Robert
Vibrating fixed! took 1 lug nut out of each front wheel and placed them in passenger rear wheel . there where only 2 lugs that was made for the wheel in it. previuos owner had plain nuts on three of the studs and only 2 of the proper lugs holding it on. so when I placed 2 more proper lugs on wheels and drove it, it ran like a dream no vibrating at all at high speeds. im so happy. craiger was right about a must to use proper lugs
post #13 of 13 (permalink) Old Feb 21st, 09, 07:55 AM
Shane
sounds like you may have the wrong fly wheel possibly. I used one I found that had a different tooth count, the whole car vibrated at 45 mph.
carbon69SS is offline
