1992 rear end width - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 21st, 09, 10:34 AM Thread Starter
dce
1992 rear end width
I am restoreing a 1968 SS I need a rear end I have found a 1992 camaro with posi 3.73 gears and disc brakes on craigslist does anyone how wide it is I can change the pads and shock mounts
dce is offline
post #2 of 3 (permalink) Old Feb 21st, 09, 02:55 PM
Viktor
yevgenievich's Avatar
Send a message via AIM to yevgenievich
Re: 1992 rear end width
iirc it's same width. Make sure it's not 93 rear end cause those are 2" wider.
those rear ends are not very strong tho, with good amount of power and sticky tires they break.
1992 dodge stealth, base
1989 firebird T/A, ls1/t56
1967 Camaro
1991 V2500 Suburban
yevgenievich is offline
post #3 of 3 (permalink) Old Feb 21st, 09, 03:35 PM
Depends on which rear. If it's the 9 bolt Borg Warner, it's plenty strong. They are setup for coils though, so it's not an easy conversion. Better to find an 8.5 out of a Nova/Apollo/Ventura/Omega.
go2fast is offline
Tags
rearend
