small block big block front end conversion - Team Camaro Tech
post #1 of 5 (permalink) Old Feb 21st, 09, 05:16 PM Thread Starter
Rick
What has to be done to the front end to convert a small block subframe build to a big block subframe. Just the springs? Motor mounts?
Current front end is setup for a small block with a Hotchkis TVS 2"drop, bilstein shocks.
dukemd66 is offline
post #2 of 5 (permalink) Old Feb 21st, 09, 06:02 PM
Gary
Re: small block big block front end conversion
Lots of things....springs, motor mount towers, tranny crossmember, fan shroud. 4 speed requires different shifter mounting bracket and linkage.
It's worth it, though!!
Unreal is offline
post #3 of 5 (permalink) Old Mar 20th, 09, 07:25 PM
Rob
I put a tall deck in my 81, had a 267. Bolt it in buddy! If your goin with tall covers...you'll need a 8 inch booster and cut your hood...lol.
Mad Max is offline
post #4 of 5 (permalink) Old Mar 20th, 09, 08:00 PM
Craig
Do a search on this topic. You should find a ton of discussions on it. I know its been discussed at length many times in the past.
thorpe67RS is offline
post #5 of 5 (permalink) Old Mar 21st, 09, 12:11 AM
Ed
BigBlock1969RS's Avatar
Classic Industries has a nice article on this subject as well:
http://www.classicindustries.com/con...rationTip&pt=1
Ed
BigBlock1969RS is offline
