Brake kits - Which ones??? Help a man make up his mind!!! - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 22nd, 09, 07:51 PM Thread Starter
Matt
I sure wish it was simple but it's not as I've been chewing on this for days. I am converting my 68 from manual 4 drums to 4 disks. I will run 17 inch wheels so I am in the market for 12-13 inch rotors. I would like to start with the front first. I haven't decided if I will go power/manual yet. The bigger decision I need help with is which kit. I have looked at Wilwood, CPP, ABS and a few others in between. I have searched this site inside and out finding a little good about each one. I have found a little more negative stuff about CPP then others. So far, I am leaning towards Wilwood's kit "Dynalite Big Brake". Kit includes:
Calipers, Hubs, Rotors, Brake pads, Mounting brackets, Hats, Hardware, Installation instructions. In addition to this, I will need: Master Cyl, booster, adjust prop valve, flex break line kit.
According to what I read, I should be able to reuse my stock drum spindles.
Has anyone used this setup before or perhaps another one that they are happy with?
What else will I need to make this complete?
I sure wish there was one kit out there instead of dozens, but than again thatís the beauty of a free market.
Thanks in advance...
Matt
zlek131 is offline
post #2 of 10 (permalink) Old Feb 22nd, 09, 08:10 PM
Jess
Re: Break kits - Which ones??? Help a man make up his mind!!!
not trying to steal your thread here but Im looking for somewhat of the same info. Ill be switching the front drums on my 69 to discs and Im looking for the best kit. Right now Im thinking ssbc but if I was an all knowing expert I wouldnt be on the forum! lol. any advise would be helpful. Im going to be running a 15 inch wheel to start and will convert to an 18 inch set later. Id also like to go with a brake company that I could basically upgrade to the bigger rotors and more piston calipers when I go up in wheel size.
69 Jess is offline
post #3 of 10 (permalink) Old Feb 23rd, 09, 12:07 AM
Re: Brake kits - Which ones??? Help a man make up his mind!!!
keep your stock drum hubs and order 13" rotors, calipers, and baskets for a later model Corvette- the year doesn't really matter as long as it's 88 or so and newer and everything is from the same year.
make some 1/4" steel brackets to mount the Vette baskets and machine your drum hubs down to fit inside the rotors.
it is a simple swap that works- you won't need a power booster of any kind and your car will just flat out stop when you hit the pedal.
you don't plan sincerity.
novaderrik is offline
post #4 of 10 (permalink) Old Feb 23rd, 09, 09:37 AM
Rob
RockinRob's Avatar
i did the Right Stuff Detailing upgrade to power w/ discs on front. Kit was complete and everything fit as it was supposed to. also got new lines from them.
Rob
67 base convertible, GMPP 350/330 HO, TKO500....
Taken around the block for the first time 12/2/07
Finaly getting some paint Sept. 2009
RockinRob is offline
post #5 of 10 (permalink) Old Feb 23rd, 09, 09:43 AM
Joe
Jess, Matt
I did the a 4 wheel disc power brake conversion last year on my 69 Camaro. I had 4 wheel power drums and was able to keep my stock drum spindles. The system works great and looks awesome. Check my link below for some pictures of the parts and the install. I went will all new stainless steel brake lines, 11 booster, 1 1/8 " bore master cylinder and a "combination valve" for 4 wheel disc applications. I purchased everything (except for booster, master cylinder, combination valve and brake lines) from Dean at Hotrodusa..see link attached. The Wilwood system even includes the rear parking brake components to hook up your stock cables. I did not want to use the Wilwood adjustable proportioning valve that Wilwood sells use nor did I like the look of their master cylinder. If you need more info PM me. I recommend you give Dean a call if you like the Wilwoods.
The stainless brake lines I got from Right Stuff Detailing...as far as I am concerned they were the best and helped me out a lot.
Good luck. Joe
http://www.hotrodsusa.com/
Z282NV
1969 Camaro
Z282NV is offline
post #6 of 10 (permalink) Old Feb 23rd, 09, 10:14 AM
Jeff
68IslTeal's Avatar
Check out stainless steel brakes
Ordered their front conversion kit, I think its price was reasonable, the parts were top notch and iconversion was a breeze. They sell a rear conversion kit also, but that will ome later for me.
68IslTeal is offline
post #7 of 10 (permalink) Old Feb 23rd, 09, 10:49 AM
Chris
130fe's Avatar
Thumbs up Re: Brake kits - Which ones??? Help a man make up his mind!!!
If you are looking for a good deal to upgrade (from drums), this is one https://www.camaros.net/forums/showthread.php?t=150333 from one of our sponsors (Frank @ Prodigy Customs). Pretty good deal for everything to do it.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #8 of 10 (permalink) Old Feb 24th, 09, 05:52 AM
Creight
Feel free to pm me on brake kits. I carry Baer, SSBC and Wilwood.
CS3 Auto is offline
post #9 of 10 (permalink) Old Mar 11th, 09, 04:05 PM
I am looking for a buyer for a Master Brake Cylinder #5470409 1 1/8 that I purchased new. It's in great shape. Will ship within US. It fits a 70-72 vintage Chevelle, Camaro, among others.
Please contact
970-314-5553
[email protected]
d81529 is offline
post #10 of 10 (permalink) Old Mar 11th, 09, 05:09 PM
Andrew
Andrew69's Avatar
These guys have good stuff http://www.touring-classics.com/Brake%20Kits.htm
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
