1968 Disc brake conv question - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 23rd, 09, 01:33 PM Thread Starter
Bill
Hello all, new guy here I hope its ok to ask this here. I bought a 68 Camaro a few weeks ago, just started rounding up parts to put back together. Someone had set it up for a drag car, with a roll bar, fuel cell and spool type rear axle but that's for another time. It has disc brakes on it but I think they are the four piston kind, the calipers are missing but the rotors are still on there. I want disc brakes for sure, is it worth getting the four piston type calipers or should I just get the stuff to change to the one piston version? I have always been told the 4 piston type were not very good. Any help is appreciated.
GasserOhio is offline
post #2 of 3 (permalink) Old Feb 23rd, 09, 01:52 PM
Rick
Re: 1968 Disc brake conv question
Don't Know anything about the original 2 piston type caliper. I would say if you want to stay all original stay with them. If not I put the 69/70 nova spindles and calipers on my 68 single piston's and went to 15 inch rally wheel's all around. I don't know if you can get the 14 inch wheels to go over the nova calipers or not If your staying with 14 inch wheels you should find out first
yoddy is offline
post #3 of 3 (permalink) Old Feb 23rd, 09, 02:09 PM
I have never seen 2 piston calipers for a 67-68 they were 4 piston, if you want total orig finf 4 piston, but the car is modified already, change the caliper braclets an use single pistion 69-72 a lot cheaper, and easier to work on. I had a set of 4 pistion, used a set from a 72 monte, to rebuild calipers was 2-3 hundred at the time.
john68 is offline
