Where to Pull Brake Booster Vacuum? - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 23rd, 09, 03:55 PM Thread Starter
Josh
Where is the best place to pull vacuum pressure for your power brake booster? the intake or back of the carb?
1968 Camaro BBC 396
2007 TrailblazerSS LS2 400HP
z585 is offline
post #2 of 13 (permalink) Old Feb 23rd, 09, 04:04 PM
Brandon
Re: Where to Pull Brake Booster Vacuum?
whichever is easiest and most accessible.
Brandon J. licence 1NASTY67
Nantooch is offline
post #3 of 13 (permalink) Old Feb 23rd, 09, 04:09 PM
Skip
Skeeter55's Avatar
X2 but ive been told that the carb may be better and it depends on the intakes vacuum location. Mine is on the intake but im gonna switch it to the carb.
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #4 of 13 (permalink) Old Feb 23rd, 09, 04:10 PM
Tony
you can pull from either location but make sure that you're pulling manifold vacuum and not ported
eastcoast is offline
post #5 of 13 (permalink) Old Feb 23rd, 09, 04:16 PM
Howard
Are you using a PCV Valve also? I found that booster vac.is best from the intake, PCV from the 3/8 port on the throttle plate.
Just Having fun with all My Big Block Toys!!!
bbmusclecars427 is offline
post #6 of 13 (permalink) Old Feb 23rd, 09, 04:16 PM Thread Starter
Josh
Cool thanks guys!! Does anyone know why when my car is idling I can unplug the brake booster vacuum and the idle increases? I am going to get a vacuum gauge to see what i am getting.
1968 Camaro BBC 396
z585 is offline
post #7 of 13 (permalink) Old Feb 23rd, 09, 04:26 PM
Howard
Because the diafram inside the booster pulls to a certain position and "holds" the level of vacuum (lower).Once you pull it off,the engine vacuum has nothing to limit it.With the line off the booster (engine idleing) the RPM'S increase because the raw vacuum has now activated the advance weights in the distributor adding more RPM'S.
post #8 of 13 (permalink) Old Feb 23rd, 09, 04:32 PM Thread Starter
Josh
Sweet! Thanks everyone!
1968 Camaro BBC 396
z585 is offline
post #9 of 13 (permalink) Old Feb 23rd, 09, 06:42 PM
DjD
DjD's Avatar
How does a vacuum leak cause the advance weights to move?
...Dennis
DjD is offline
post #10 of 13 (permalink) Old Feb 23rd, 09, 07:07 PM
gary
The vac leak is adding air to the engine (just like opening the butterflies in the carb). More air more RPM (albeit not metered air) so it is leaning out some too which also raises RPM.
pro70z28 is offline
post #11 of 13 (permalink) Old Feb 24th, 09, 03:43 PM Thread Starter
Josh
So I got a vacuum gauge and check vacuum at the booster and I am getting 8psi at idle. That doesn't sound good to me??
1968 Camaro BBC 396
z585 is offline
post #12 of 13 (permalink) Old Feb 24th, 09, 05:33 PM
gary
Are you connected to vac below the throttle blades?
pro70z28 is offline
post #13 of 13 (permalink) Old Feb 24th, 09, 06:08 PM Thread Starter
Josh
Yes using the port on the back of the carb.
1968 Camaro BBC 396
z585 is offline
