69 disc brake backing plates - Team Camaro Tech
post #1 of 9 (permalink) Old Feb 24th, 09, 03:07 AM Thread Starter
Anyone got a picture of the correct PDB backing plates for a '69? I've got some generic (read as repop) ones that have a cup spot welded to the plate, but the rotors won't fit inside this cup. I'm thinking that the original backing plates didn't have this cup, but I'm not sure.
buenymayor is offline
post #2 of 9 (permalink) Old Feb 24th, 09, 06:11 AM
Jeff
yellow69RS's Avatar
Re: 69 disc brake backing plates
I have a Polaroid pic of this in my album but no way to scan it in. The cup is there. Without taking my car apart I can't be 100% sure but I think the rotor might have a turned section that fits into the cup with clearance.
Jeff
yellow69RS is offline
post #3 of 9 (permalink) Old Feb 24th, 09, 12:12 PM
Robert
The cup is there, orig or re-pop. Sounds like you either got a bad set or some thing else is going on.
1stGenLvr is offline
post #4 of 9 (permalink) Old Feb 24th, 09, 09:16 PM Thread Starter
Anyone got the measurements of the ID of the cup and how deep it is? I'm using one piece rotors, too. Maybe that has something to do with it?
post #5 of 9 (permalink) Old Feb 25th, 09, 09:44 PM
Robert
69's came with 1 piece rotors. Are you running the 69 single piston caliper or an early 4 piston set up?
post #6 of 9 (permalink) Old Feb 26th, 09, 01:24 AM Thread Starter
I know at least the early '69s used a 2 piece rotor. I've got the single piston calipers, but I can't get the rotors on, much less the calipers.
post #7 of 9 (permalink) Old Feb 26th, 09, 07:18 AM
Robert
I should be able to take some measurements today.
post #8 of 9 (permalink) Old Feb 26th, 09, 09:19 AM
Robert
The orig BP i.d. is 3", the 1 piece rotors are machined to 2 3/4". The aftermarket BP is 3.25" i.d. Are you using the correct rotor? Should be Bendix 141039, Raybestos 5100, Dura 5514 just to name a few.
post #9 of 9 (permalink) Old Feb 26th, 09, 08:35 PM Thread Starter
Thanks, Robert, that is exactly what I was looking for. I'll have to measure mine this weekend and check it out. Just from memory, I don't think the cups on mine are 3" That would explain the problem. Thanks again!
