What is this - Team Camaro Tech
post #1 of 13 (permalink) Old Feb 24th, 09, 06:24 PM Thread Starter
Joe
What is this
On a power disk brake car, there is little round thing that mounts to the booster. The line from it goes into the front tapped hole of the master cylinder. Have not seen this before. I will try to get a pic later.
OK69 is offline
post #2 of 13 (permalink) Old Feb 24th, 09, 06:42 PM
Art
Re: What is this
This?
Artie
67 Camaro
99 T/A Daily Driver
Previous:
67 Camaro Traded for my 98
68 Camaro Street/Strip
98 Camaro Race car Best ET 9.08 @ 152 1.18 60'
Dyno sheets don't win races, see you at the track
SRGN is offline
post #3 of 13 (permalink) Old Feb 24th, 09, 07:00 PM
jeff
1SLOW64's Avatar
Re: What is this
not sure? what is it? Poportioning valve?
1969 X66 PROJECT:
2002 C5 COUPE ELECTRON BLUE SOLD
1987 BUICK GRAND NATIONAL SOLD
1964 CHEVY II 406 SOLD
1SLOW64 is offline
post #4 of 13 (permalink) Old Feb 24th, 09, 07:12 PM
mark
Re: What is this
yes that's what it is!
68 SS CAMARO 355,victor jr. intake,performer rpm heads,Quick Fuel carb,Isky z-27 solid cam,TKO 600,4.11 12 bolt,Hotchkis springs front & rear,Flowmaster exhst.
blk/gld 68 is offline
post #5 of 13 (permalink) Old Feb 24th, 09, 07:31 PM Thread Starter
Joe
Re: What is this
Originally Posted by SRGN View Post
This?
Yea, does that come on all Power disk brake cars?
OK69 is offline
post #6 of 13 (permalink) Old Feb 24th, 09, 07:59 PM
T
Re: What is this
Pretty sure that's the hold-off valve. Basically prevents fluid flow to the front brakes until some pressure threshold is reached. This lets the rear (drum) brakes take up the slack in the system and apply slightly before the fronts start to do any work. Net effect is (allegedly) a stabilizing effect (since the rear brakes will tend to straighten out the car when applied LIGHTLY) and reduced front brake pad wear (presumably by increasing the rear drum wear a bit and letting the rear brakes act a bit sooner).
At some point (1971?) GM rolled the prop valve, distribution block , hold-off valve, etc. all into a one-piece combo valve, but I think "everything" with front discs and rear drums in the 67-70 range had these.
TMessick is offline
post #7 of 13 (permalink) Old Feb 24th, 09, 09:03 PM Thread Starter
Joe
Re: What is this
Thanks, that is interesting and informative. This is the first disk brake first gen car I have had.
OK69 is offline
post #8 of 13 (permalink) Old Feb 24th, 09, 09:54 PM
Send a message via AIM to RamAirDave
Re: What is this
Yep, that's the hold-off/metering valve. The prop valve is the one down on the subframe under the driver's side door.
From JohnZ
https://www.camaros.net/forums/showpo...90&postcount=9
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #9 of 13 (permalink) Old Mar 6th, 09, 01:10 PM Thread Starter
Joe
Re: What is this
OK69 is offline
post #10 of 13 (permalink) Old Mar 6th, 09, 03:33 PM
Banned
Re: What is this
I hope JohnZ is lurking b/c this is the 1st time I've heard about a prop valve being mounted down by the lower frame??
I thought that was the 10 pound rear drum brake residual hold-off valve and if it isn't, I need to remove it so my new A/M adjustable prop valve works right for my "pdqCBB" setup.
I made sure that my rebuilt P/B M/C doesn't have any residual valves behind both line port seats so need to double-check this little ditty..........
pdq67
post #11 of 13 (permalink) Old Mar 6th, 09, 05:25 PM
Re: What is this
Paul - you don't need the metering valve with 4 wheel disc brakes. Of course - in your case - it doesn't really matter on a car that sits in the garage and hasn't moved under its own power for what now - 10 years?
BPOS is offline
post #12 of 13 (permalink) Old Mar 6th, 09, 06:05 PM
T
Re: What is this
pdq67
4-wheel drum brake cars won't have a prop valve on the frame (no prop valve at all). I haven't seen a factory disc car, but the factory assy manual does show the valve located on the frame/subframe area under the driver's door opening....
And yeah, having 2 prop valves in series isn't recommended, so best bet is to remove it if you've got one...
TMessick is offline
post #13 of 13 (permalink) Old Mar 7th, 09, 04:34 PM
Banned
Red face Re: What is this
I know, I know BPOS!!
In my best Lou Costello voice, "I'm a baaaaaaad boy"!!....
pdq67
