Shock suggestions???? - Team Camaro Tech
post #1 of 10 (permalink) Old Feb 26th, 09, 06:40 PM Thread Starter
I'm gonna get my new shocks this year (to go along with my new tires!!)
I currently have 6 year old KYB Gas a Justs. It's kinda like there were sticks there instead of shocks.
My first thought is to pick up a set of bilsteins and call it good, they work pretty nice on my truck and my vette, but this lil bird on my shoulder says some sort of adjustable shock might let me get the best of both worlds by letting my optimize the damping when I go to the drag strip while still keeping a more cornering oriented setup most of the time.
What say you?
post #2 of 10 (permalink) Old Feb 26th, 09, 06:53 PM
Re: Shock suggestions????
Jim, I went back to a set of red Koni 3 way adjustables. I had this type of shock since day 2, I tried Delco, KYB and they just gave me a spongy feel. I have these shocks set on #2 setting. These were not the drag Koni's but the std red tube. I wouldn't have anything else.
80-1914 front, 80-1953 rear. These are lifetime shocks.
http://www.tirerack.com/suspension/S...lar=&brand=all These are for multi-leaf springs.
TC # 349
zdld17 is offline
post #3 of 10 (permalink) Old Feb 26th, 09, 08:41 PM
Tim
Havin' Fun's Avatar
Jim, I have a set of KYB gas-a-just KG5524 if you need a quick fix. Just show up next wednesday and theirs yours.
Havin' Fun is offline
post #4 of 10 (permalink) Old Feb 26th, 09, 08:49 PM
Joe
I just ordered front and rear shocks for my 69 Camaro from DSE. They are KONI...from all the threads I have read on this forum there are a lot of people who recommend them..DSE has the best price I could find at $99 each.
http://www.detroitspeed.com/productp...hocks_prod.htm
Z282NV
1969 Camaro
Z282NV is offline
post #5 of 10 (permalink) Old Feb 26th, 09, 10:30 PM
Harley D
HarleyD67's Avatar
Jim Rancho or QA1's for rears. As far as the front The Bilsteins are a good choice or for a little more get adjustables and go with QA1's up front as well. The adjustable Koni's are decent 3rd choice. If you decide to go with the QA1's call me or pm me before you do.
"Be who you are and say what you feel, because those mind don't matter, and those who matter don't mind."-Dr. Seuss
We learn life's important lessons in kindergarten.
Harley D
'67 coupe 427SBC
60'1.728
1/[email protected]
HarleyD67 is offline
post #6 of 10 (permalink) Old Feb 27th, 09, 07:14 AM
Randy
I've had KYBs in my 67 for 12 years, and I somehow found a full set of Varishock single adjustables just sitting on my bench.... I think Marcus at SCandC had something to do with it...
I'm going to install them very soon, and I can tell you about the change. I'm really excited to play around with the adjustments.
Randy
rlovell383 is offline
post #7 of 10 (permalink) Old Feb 27th, 09, 02:56 PM
Bill
I put the QA1 adjustables in the rear (coil-overs up front). Took a few trial and error rides to get them just right but now very happy with my car's ride/feel.
68RS-SS is offline
post #8 of 10 (permalink) Old Feb 27th, 09, 07:16 PM
Chris
130fe's Avatar
Jim you have pm.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #9 of 10 (permalink) Old Feb 28th, 09, 05:18 PM
Randy
Well, I installed my varishocks today, and wooooowwww what a difference!!!! It took a little more work than the average shock to install. You cant put them in from the bottom, because they are too big in diameter. So plan on popping the upper ball joint with these.
Also, I had to do a very small amount of clearancing around the opening on my lower control arms to fit the shock eye. But whats a performance part without a little massaging to fit it??
I took it out for a little spin this afternoon and man what a difference. I just kept them on the recommended starting point for now, because it was getting dark. 3 clicks in... A good bit softer than the KYBs but still 13 clicks more in adjustment to go. So I'm really excited to spend time dialing them in. I'm already very pleased with these. So there is my review. And thanks to Marcus at SCandC for helping me decide on these, and giving me honest straightforward advice.
Randy
post #10 of 10 (permalink) Old Mar 16th, 09, 06:55 PM Thread Starter
Done. Got some barely used QA1's from Chris above (Thanks Chris!!!) Got em installed this past weekend, and test drives yesterday and today.
These things are NICE. The suspension moves again. Smooth as silk even with those killer hotchkiss front springs. Car seems quieter, and a lot less rattly too.
These shock are big. Installation in stock lower control arms might need some grinding to clear the adjustment knob, perhaps even to fit the body through the hole. They slide right into my G/W Lower arms no problem.
