Correct upper ball joint installation - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 1st, 09, 09:06 AM Thread Starter
Louie
rad454's Avatar
I just saw a picture of an upper ball installed and bolted in under the A-arm, exactly the opposite of the factory installed riveted original.
I installed mine with the joint going down through the top of the hole in the A-arm, and then bolting that into place. This seems to fit perfectly and looks like the way it was engineered/installed from the factory.
Is this correct or did the guy whose car I saw put his in wrong?
rad454 is offline
post #2 of 6 (permalink) Old Mar 1st, 09, 09:18 AM
Re: Correct upper ball joint installation
The joint installs from on top, going down thru the a-arm.
post #3 of 6 (permalink) Old Mar 1st, 09, 01:00 PM
Seems unsafe to put it under. Just those 4 rivets or bolts between you and a big surprise.
go2fast is offline
post #4 of 6 (permalink) Old Mar 2nd, 09, 08:59 AM
Rick
I had spoken with Mark at SC&C when I installed his SPC arms on my 69. I put the BJ underneath so if/when I wanted to removed the UCA, I didn't have to break the UBJ loose from the spindle.
Rick Dorion
69 RS Conv therapy program, Autogear M22, 8-pt cage, with a new 410! SOLD
New therapy program - 68 Coupe. Will be survivor exterior, modern underpinnings! SOLD
67 Belair with perfect floors, pinchwelds and firewall. Hmmm!
RickD is offline
post #5 of 6 (permalink) Old Mar 2nd, 09, 11:45 AM
Jeff
yellow69RS's Avatar
I see no problem doing it this way either. In 15 years in the alignment business I never saw one break the bolts or rip out the rivets, I've seen more than a couple worn out to the point of separation. the stud stays in the spindle and the rivets /bolts are still in the arm but they are no longer connected. The Engineers will argue this but the upper is just a folllower, no load on it.
Jeff
yellow69RS is offline
post #6 of 6 (permalink) Old Mar 2nd, 09, 04:06 PM
I aslo talked to Mark @ SC&C when I did my SPC arms. He said either way is fine. I put mine down through the hole - don't ask me why - it seemed to make a little more sense. I see Rick's point too, though. I loctited everything and don't lay awake at night worrying about it.
BPOS is offline
