Brake Pedal Spring? - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 2nd, 09, 07:27 AM Thread Starter
Brake Pedal Spring?
The AIM on a 69 shows a spring and little attachment piece that pulls the brake pedal rearward. It's hooked , in the front to the rod whih holds the MC clevis. The spring is probably hooked under the dash rearward of the pedal. Do you guys (and gals) have this piece on your cars? I can't seem to locate it in my boxes of parts.
Thanks,
Rookobird is offline
post #2 of 3 (permalink) Old Mar 2nd, 09, 07:42 AM
Kevin
KevinW's Avatar
Re: Brake Pedal Spring?
John, it is only needed for manual brakes. If your car has power brakes, then you dont need/have it. The spring assembly also has a small eyelet that goes under the brake clevis that the spring hooks to.
Kevin
KevinW is online now
post #3 of 3 (permalink) Old Mar 5th, 09, 07:18 PM Thread Starter
Thanks Kevin! What you described (eyelet) is the bracket piece I was talking about. I'm glad I don't need it.
