DSE weld in frame connectors - Team Camaro Tech
post #1 of 11 (permalink) Old Sep 18th, 09, 09:14 PM Thread Starter
Kurt
camsdad's Avatar
Greetings to all!
I would like to see some ground clearance side shot pictures of the DSE weld in frame connectors welded or bolted to the front subframe on 1st gen Camaro's after they have been installed and the car is back on the ground.
Anybody got any they can post here???
Thanks in advance.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #2 of 11 (permalink) Old Sep 19th, 09, 02:34 PM
Re: DSE weld in frame connectors
What you see under the car just in front of the rear tire is the muffler case; the DSE SFC is higher still.
and
in this case the lowest thing you can see is the u-bolts for the leaf springs and the muffler case.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #3 of 11 (permalink) Old Sep 19th, 09, 03:29 PM
Jay Livingston
In my opinion the DSE connectors are the best fitting, tucked up under the body, structrual ones out there. Be warned thou you have to cut up the floorpan a little, but well worth it.
67Camaro972 is offline
post #4 of 11 (permalink) Old Sep 19th, 09, 03:38 PM
Mike what type suspension are you running ?Tire /rim size ?The stance your car has is perfect .
kleptopigdog.........68 camaro in about a hundred peices
lifes a garden , dig it joe dirt 2001.......
kleptopigdog is offline
post #5 of 11 (permalink) Old Sep 19th, 09, 05:46 PM
Tires are easy - those are stock C5 wheels - 18x9.5 rear with 275-35-18 tires; 17x8.5 front with 245-45-17 tires
Suspension is a little more complicated because it's not a kit. The rear springs are "Carl Casanova" spec Flex-a-Form composite leaf springs (about a 225 lb./in. rate) with the eyelets flipped over to drop the rear end. The front is AFCO spring adjusters with AFCO 650 lb./in. 9.5" coil springs. Adustable Koni's all around, Gulstrand mod up front, stock control arms with delrin bushings and solid body bushings.
Everything is available on line.
Mkelcy is offline
post #6 of 11 (permalink) Old Sep 20th, 09, 09:27 AM Thread Starter
Kurt
camsdad's Avatar
Mike,
Nice ride there
Well, I was unable to find any close up pics and the installation instructions that come with the DSE don't help either.
So, here is what I ended up with.
Boy, I sure hope I did it correctly. I would have thought they would have been parallel to the subframe before the taper.
What do you think?
Kurt
383CID Lives
camsdad is offline
post #7 of 11 (permalink) Old Sep 20th, 09, 09:43 AM
Skip
Skeeter55's Avatar
Man looks great...
I NEED TO HIT THE LOTTERY
Skeeter55 is offline
post #8 of 11 (permalink) Old Sep 20th, 09, 11:34 AM
Originally Posted by camsdad View Post
Mike,
Nice ride there
What do you think?
Those look fine, probably about the same as on my project '68 (not the one above) or higher.
Mkelcy is offline
post #9 of 11 (permalink) Old Sep 20th, 09, 03:01 PM
Todd
They are a really nice piece and tuck up tighter than the exhaust and subframe for that matter.
Vegas69 is offline
post #10 of 11 (permalink) Old Sep 20th, 09, 03:18 PM
erik
On mine they are about 1/4" below the floor pan. easy to install and i am more than happy with them.
tumper is offline
post #11 of 11 (permalink) Old Sep 20th, 09, 11:30 PM
Probationer
That car is gorgeous How much cutting did you have to do? I was thinking about going with the hotchkis cause i hear they tuck up real nice but these things look awesome!
BigDave is offline
