67 disk brakes - Team Camaro Tech
post #1 of 11 (permalink) Old Oct 14th, 09, 07:15 PM Thread Starter
Nick
67 disk brakes
dose any one have a part # for the one piece rotor for a 67 ?
it has to be a after market rotor like raybestos,or?
also I need a # for the master cylinder.
Thanks. Nick
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #2 of 11 (permalink) Old Oct 16th, 09, 03:09 AM
Re: 67 disk brakes
OE rotors were 2 piece.
Classic Muscle have the USA made 1 piece #3901098R.
Master #3909903.
www.oldmusclecars.com
Does this help?
BlackoutSteve is offline
post #3 of 11 (permalink) Old Oct 16th, 09, 03:43 AM
BILL
SPARKY69's Avatar
Re: 67 disk brakes
67-69 camaro are the same and 68-72 nova are the same both for the rotor and the master cylinder!!..your local auto parts store should have these available in bendix brand too!
SPARKY69 is offline
post #4 of 11 (permalink) Old Oct 16th, 09, 07:04 AM Thread Starter
Nick
Re: 67 disk brakes
Thanks guys...Just order some.
Nick
post #5 of 11 (permalink) Old Oct 26th, 09, 03:46 PM Thread Starter
Nick
Re: 67 disk brakes
well I got my rotors on today and they don't fit, the caliper is touching the rotor hub and it makes all kind of noise I got the raybestos 5100R rotors and they fit from 67 to 72 Camaros, Novas. The old rotors hat about 1/2 clearances from hub to rotor.
Can someone please help.
Thanks. Nick
post #6 of 11 (permalink) Old Oct 26th, 09, 05:38 PM
David Pozzi
davidpozzi's Avatar
Re: 67 disk brakes
If you have the 67 or 68 factory 4 piston calipers, you need the special reduced hub one piece rotors.
davidpozzi is offline
post #7 of 11 (permalink) Old Oct 26th, 09, 05:59 PM Thread Starter
Nick
Re: 67 disk brakes
Thanks David. yes thats what I have, the 4 piston caliper. Would you have a part # or what years and makes models do the fit?
Thanks. Nick
post #8 of 11 (permalink) Old Oct 26th, 09, 06:38 PM
David Pozzi
davidpozzi's Avatar
Re: 67 disk brakes
Found one on Rock Auto, does this look like the hub is small enough?
RAYBESTOS Part # 5100R More Info {Professional Grade; Outside Diameter 11.005" / 5 Bolt Holes}
Front; Dual Piston Calipers
http://www.rockauto.com/
post #9 of 11 (permalink) Old Oct 26th, 09, 09:59 PM Thread Starter
Nick
Re: 67 disk brakes
Hi David. That's not the reduced hub rotor, that's is what I got the 5100r and they are touching. I know someone is making this rotor because Ricks has them and other place also have them. I think the correct rotor is made for a different application and NOT for a Camaro. I have a friend in the parts business and he is trying to help me but we keep coming up with this 5100R #
Nick
post #10 of 11 (permalink) Old Oct 27th, 09, 07:01 AM
Robert
Re: 67 disk brakes
You can't get a reduced hub rotor at a parts store, 67-68 4 piston rotors are obsolete. The 5100 is the 69 Camaro single piston, 69-72 Chevelle rotor which is essentially the same except for the larger dia hub. You can get them through aftermarket sources as they are reproduced.
1stGenLvr is offline
post #11 of 11 (permalink) Old Oct 27th, 09, 07:51 AM
Re: 67 disk brakes
Guys,
I just went through this......the 5100R is the correct rotor for the 67-68 Camaro with four piston calipers. I had my calipers rebuilt by Vette Brakes, got the correct brackets, and the 5100R rotors. Everything fit like a glove. I think if I were you, I would recheck the installation. I have one of the original 2 piece rotors, but couldn't find a second one.
67 3L 4P Project Car
I just had to have some wings.
67 RS/SS Pictures
cpodeep is offline
