69 SS 396 COUPE front spring issues - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 15th, 09, 06:49 PM Thread Starter
troy
hay guys, i just installed what was supposed to be a moog 638 in my car, and it rubs bad!!i have new 215 70/15 radial t/a all around..this is a non AC car 396 350hp, and i am really confused why this happened...were they missed labeled? if these are labeled correctly,[hoping i can read the marks] what is my next step for a spring? any thoughts?! thanks for all your help
20round is offline
post #2 of 5 (permalink) Old Oct 16th, 09, 03:43 AM
Dan Ensign
Re: 69 SS 396 COUPE front spring issues
That spring is listed for a 69 z28. SB car not BB.
Dan E.
69 SS396 4spd. 4.10 posi. x66 coupe
Dan E. is offline
post #3 of 5 (permalink) Old Oct 16th, 09, 03:57 AM
BILL
SPARKY69's Avatar
the front tire needs to be a 215-60-15(225-60-15)..what is the offset(backspace) on the rim??..15x6,7,8,??..4.5,4.3/4??..THE 215-70-15 is a skinny tire..is the top of the tire hitting the inner fender well??
SPARKY69 is offline
post #4 of 5 (permalink) Old Oct 16th, 09, 04:37 AM
Kevin
KevinW's Avatar
638 is a BB spring, 6308 is the Z spring.
Troy, define "rubs bad"? 215/70s are pretty skinny tires by todays standards. Does it rub when turning or rub the wheel well? mis-labeled springs is common. I ordered 6308 springs from Amazon and got 6320s, but since I have verts I need the 6320s
You have to mic the wire dia and free height to be sure of what you have. I have a set of new but old TRW springs I got from Jerry that mic out as 638s. he put them on a Z and it raised the front end too high.
Kevin
KevinW is offline
post #5 of 5 (permalink) Old Oct 16th, 09, 09:04 AM
My 638s had "638" stamped into the top coil. They were 1980s vintage, so I don't know if newer ones would be stamped. The 5370s I just put in were not stamped.
As Bill noted, the backspace is really important, particularly on a 69. I have 215/60 15 on my 69, with 4.75 inch BS, and no rubbing, even when the car had 638s with a coil cut off (very low).
Do you have any pics you can post, and give a little more info on where it rubs? I assume it is hitting the inner fender bolt heads at the top of the wheelwell.
Eric
Eric Kammerer is offline
