C5 brakes on rear - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 16th, 09, 06:04 AM Thread Starter
Ronnie
Question C5 brakes on rear
I've been doing a fair amount of research and decided to put C5 brakes on the front of my '69 and would like to pair that with C5 on the rear. I have a 12 bolt that's been modified with strange rear axles. Does anyone have any information on what this would take?
rons69camaro is offline
post #2 of 6 (permalink) Old Oct 16th, 09, 07:21 AM
BILL
SPARKY69's Avatar
Re: C5 brakes on rear
have you done a search on hear..im thinking david pozzi or somebody here has done it??
SPARKY69 is offline
post #3 of 6 (permalink) Old Oct 16th, 09, 07:48 AM Thread Starter
Ronnie
Everything I've found so far is for a 10 bolt rear end...
post #4 of 6 (permalink) Old Oct 16th, 09, 07:53 AM
BILL
SPARKY69's Avatar
Originally Posted by rons69camaro View Post
everything i've found so far is for a 10 bolt rear end...
whats the diff. In the 10 bolt or 12 bolt? The backing plates ,axles and tubes are the same ??.i would think they would configure up the same??
SPARKY69 is offline
post #5 of 6 (permalink) Old Oct 18th, 09, 03:30 PM
Do you have C-clip axles? Do you want an e-brake? If yes....
The LS1 rear swap is way easier and way cheaper. The brakes are essentially the same as C5 rears. Same rotor diameter and thickness (12 x 1)(but not directional) and the calipers are virtually identical - the main diff being the C5 is pressure cast vs the LS1 being gravity cast.
If you "gotta" have a C5 caliper it will bolt directly to the LS1 abutment, but you might have to mess with the anti rattle spring.
BPOS is offline
post #6 of 6 (permalink) Old Oct 19th, 09, 09:28 AM Thread Starter
Ronnie
I have the stock GM drum set up with Ford strange axles to elimate the c-clips. I would like to maintain an e-brake also...
