im looking into getting some disc brakes for my 68 camaro and i like the wilwoods, http://www.wilwood.com/BrakeKitsProd.aspx?itemno=140-10510-DR, but i was wondering how can you make sure they fit in your rim, and is there anything better out there for smaller wheels?
I've had Wilwood's on my 68 with 15" rims for the past 10 years.
Back then Wilwood didn't offer a special package for conversion so I had to use their Dynalite Pro 4-piston calipers for a 12 bolt with separate e-brake calipers. The clearance is fine up front but really tight in the rear, maybe 1/8" at most. Stopping is great even though they aren't the huge brake kits most folks install today.
Fronts are 10.75" rotor #140-2285
Rears are 12" rotor #140-2277
I am running Wilwoods 140-7675 fronts and 140-9560 rears with 18 inch rims on my 68. Same rotor (12.19) size but 4 piston calps instead of the 6 piston in your kit above. I thought I read a while back somewhere that these would not fit 15 inch rims but I am not 100% positive. I would call Wilwood and talk with one of the tech guys. I found them to be very helpful and knowable. I really like the kits and the price was good too. I have the drilled/slotted rotors and red calipers. BTW, the rear kit is for the big ford flanges as that's what I have on my rear end.
Yes, one of the manufacturer's of aftermarket brake kits offers a disc brake kit, 2-wheel and 4-wheel, that will fit with 14" or larger wheels. ...... I don't recall who they are, but they advertise in Super Chevy and Chevy High Performance magazines every month.
He can sell you a complete package with braided ss hoses, park brake cable kit, clips, bracets, brake fluid etc. Check my link below for some pictures of the install.
OK, I got your answers. They can be found easily on Wilwood's website. If you follow the link that you provided in your initial post, you will see that minimum rims required for your kit are 16 inches (right side, middle of page). Joe's and RJ's 140-2285 kit requires a minimum 15 inch rim. My kit 140-7675 requires a minimum 16 inch rim.
i did see that but i was just kinda asking around and seeing whats up and i dont really know how to measure the wheel to see what will fix but i think i will have to give wilwood a call
Ok, I'm not a fan of "big-wheels" on 1st gens. They just don't look right. If you agree, look at ABS Power Brake. According to their ad, they make a four wheel disc kit that fits 14" and 15" wheels. www.abspowerbrake.com
Related Threads
Team Camaro Tech
2.4M posts
83K members
Since 1998
