Mono vs Multi Shock Plates - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 25th, 10, 08:18 PM Thread Starter
I've read on the site that the multi leaf spring perches are wider than the mono perches.
If true, then a question: Is the bolt spacing on a mono shock plate the same as on a multi shock plate? Thanks!
BPOS is offline
post #2 of 3 (permalink) Old Feb 25th, 10, 10:04 PM
MCB
MCB Parts
Send a message via AIM to MCB
Re: Mono vs Multi Shock Plates
Bolt spacing is the same. They use diff. lower shock mounts and the multi pleaf plate is thicker metal.
MCB is offline
post #3 of 3 (permalink) Old Feb 26th, 10, 07:29 AM Thread Starter
Thanks Matt
BPOS is offline
