69 Z28 rear wheels lockup - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 1st, 10, 06:18 PM Thread Starter
Ok the car has been sitting for months, I take it out for a drive & the rear tires lockup on anything but real easy slow stops. No fun to drive when you can't step on the brakes for fear of the rearend coming around. So I read all the posts I could find & it looks like its the proportioning valve giving too much pressure to the rears. So it is the valve attached to the frame below the floor right? Any sources for a replacement?
Bill
billyd is offline
post #2 of 3 (permalink) Old Mar 2nd, 10, 03:12 AM
Re: 69 Z28 rear wheels lockup
It could be the valve is cutting off the front brakes.
Look at the tip of the rod pointing front wards. There should be about 1/4 inch sticking out.
If more, then a hard & fast rear bleeder open will reset the valve.
You might find a replacement at your local parts store.
post #3 of 3 (permalink) Old Mar 2nd, 10, 03:44 AM
BILL
SPARKY69's Avatar
As above and
wheel cyl's could be bad
check your rear brake situation too
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
