69 Front Disc Brake Conversion - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 29th, 10, 05:45 PM Thread Starter
Brian&Jennifer
I have a 69 Camaro (Racing) - that I have converted the front drums to disc brakes. I am still running drums on the rear.
I have bought the proportioning valve and new brake lines as instructed to do so when performing this conversion. Now I am not able to get any pressure to stay in the front brakes. I can pump them about 15 to 20 times and get pressure but once I let off - they won't hold pressure.
My question to you is - what master cylinder should be used? I bought a new master cylinder (as instructed) so I don't have my original that was on the car.
My next question: I was also told that I would only need the proportioning valve as well and nothing else - is this the case or am I missing something else?
jbjathompson is offline
post #2 of 2 (permalink) Old Apr 29th, 10, 06:11 PM
Re: 69 Front Disc Brake Conversion
What kind of brakes did you buy? Stock replacement type, aftermarket? Did you bench bleed the MC? Sounds like air (lots) in the system.
BPOS is offline
