Line Loc & Proportioning Install.... LOTS PICS - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 30th, 10, 04:07 AM Thread Starter
Filip
Hi All
Don't know if this is interest to anyone, but I am just about to install my new Booster and Master cylinder. So I thought I would install a Line Loc and a adjustable proportioning valve at the same time. The 68 is an Auto so Im running the Line Loc to the rear brakes , so it essentially when the switch is flicked the brake will only operate the front brakes. I wish brake lines were like the internet and were wireless so I have done my best to keep oll the line , valves etc as tidy and as compact as possible.
Here is the Hurst Line Loc
[IMG][/IMG]
Adjustable Valve with integrated brake light switch
[IMG][/IMG]
Here is the new Booster and Wilwood cylinder
[IMG][/IMG]
First I made a cardboard template to gauge what I can fir without running interference from the inner guard
[IMG][/IMG]
Transfer basic shape to 6mm Aluminum
[IMG][/IMG]
Using a drill and a Jig saw I cut out the basic shape
[IMG][/IMG]
After a little work with the file I put it in the vice and bent the vale support
[IMG][/IMG]
Bolting up the units for a test fit before polishing the bracket
[IMG][/IMG]
The bracket is sanded with 400, 800,1200 1500 and then a quick polish with Autosol
[IMG][/IMG]
Bolted together and starting to make the brake lines
[IMG][/IMG]
kiwicamaro is offline
post #2 of 6 (permalink) Old Apr 30th, 10, 04:10 AM Thread Starter
Filip
Re: Line Loc & Proportioning Install.... LOTS PICS
Line are all made ready to be bolted in the car
[IMG][/IMG]
[IMG][/IMG]
post #3 of 6 (permalink) Old Apr 30th, 10, 04:25 AM
Dave C
First few pics I was thinking man this aint going to be good.It turned out and polished up like a jem.I like it,very nice work.What bore size did you go with.Dont let any one talk you into DOT-5 fluid Wilwood doesn't recomend it at all.I found this out the hard way.
PRO.ST69orange
post #4 of 6 (permalink) Old Apr 30th, 10, 04:34 AM
BILL
SPARKY69's Avatar
Nice job and thanks for sharing!
BILL D.
JOHN 3:16
SEMPER FI
SPARKY69 is offline
post #5 of 6 (permalink) Old Apr 30th, 10, 04:52 AM Thread Starter
Filip
Thanks, I ended up going with the 1" bore after recommendation from the brake specialist, I suppose time will tell if his calculations were correct, I can swap it out if I'm not happy, Thanks for the tip on the DOT-5 fluid, in New Zealand most if not all fluid is DOT-5 so would have probably put it, not knowing.
post #6 of 6 (permalink) Old Apr 30th, 10, 08:29 AM
Nevin
Wow nice job!!! Let us know how the system works.
NOR_CAL_67rs is offline
