67 327 power steering pump bracket - Team Camaro Tech
post #1 of 9 (permalink) Old May 4th, 10, 07:01 AM Thread Starter
Loreto
Can anyne tell me if the power steering pump bracket goes between the block and the engine mount or between the mount and the bolts?
loreto67rs is offline
post #2 of 9 (permalink) Old May 4th, 10, 01:00 PM
Vince
Re: 67 327 power steering pump bracket
Pretty sure mine is beween the block and mount.
1967 327 4spd convertible 119K
1968 RS Z/28 04D Norwood have owned twice
1968 RS Z/28 04D Van Nuys asleep for 36 years
1969 Z/28 X33
3forme is offline
post #3 of 9 (permalink) Old May 4th, 10, 01:06 PM
JohnZ's Avatar
It goes between the bolt and the mount; if you put it between the mount and the block, the bracket will be crooked, and the mount will be misaligned to the frame bracket.
JohnZ
CRG
JohnZ is offline
post #4 of 9 (permalink) Old May 4th, 10, 01:43 PM Thread Starter
Loreto
Makes sense. I'll remove the 2 bolts on the mount and try to get the bracket on top of the mount and not under it. thanks..I'll post my result
post #5 of 9 (permalink) Old May 6th, 10, 10:24 AM Thread Starter
Loreto
The bracket I was using actually goes between block and mount because the bracket is unable to get past the flange if you attempt to bolt it on top of the motor mount. I found and used a different bracket instead. This one attaches under the front pump bracket and the front bolt of the motor mount. It seems to work nicely because I was able to install the pump with all necessary bolts and nuts. The one issue is the pump pulley doesn't line up with the front groove of the double pulley on the harmonic balancer, it's off by about 1/2". Any ideas? fyi, m/s to p/s conversion.
ps.. I tried to attached an image but site prevents me due to the 80KB attachement puts me 80KB over quota but I only have 2 other attachments on file.. both relatively small.
post #6 of 9 (permalink) Old May 6th, 10, 02:21 PM
Brandon
Look in the parts catalogs for the power steering pully. You may have the wrong one now. I have two separate pullies on the balancer. A shallow pully for the PS that goes between the balancer and the pully for the water pump. Everything lines up fine.
Brandon J. licence 1NASTY67
Nantooch is offline
post #7 of 9 (permalink) Old May 7th, 10, 12:49 AM
cb
Send a message via Yahoo to flyingskibiker
AIM shows something like this bracket going on top of the motor mount...
http://www.parts123.com/parts123/yb.dll?parta~partsort
I have one of them sitting around. I should try and get rid of it...
'68 SS Camaro w/ a '66 427/425 28 year project and counting!
flyingskibiker is offline
post #8 of 9 (permalink) Old May 9th, 10, 04:31 PM Thread Starter
Loreto
I wasn't able to open the link to parts123. flyingskibiker, can you send me a picture and more info of the bracket you have sitting around
post #9 of 9 (permalink) Old May 10th, 10, 09:29 PM
cb
It's basically this bracket:
http://www.firewheelclassics.com/sto...pID=&SKU=STP19
Mine is a repro. The one I have isn't so shiny... Since I have a big block, it is incorrect for my car. I'm pretty sure it came w/ some other parts I ordered. Looking closely at it, it kind of looks like it has been mounted at one time. Maybe it was a return, was put in the wrong kit, and that's why it is flat black???
