67 Camaro disc brake upgrade/9 inch rear - Team Camaro Tech
post #1 of 7 (permalink) Old May 11th, 10, 12:19 PM Thread Starter
Eli
Does anyone know of a company that sells wilwood kits for a camaro but will do a custom kit for a 9 inch rear?
Thanks in advance
Eli's67 is offline
post #2 of 7 (permalink) Old May 11th, 10, 02:23 PM
Send a message via AIM to boostin05blacksti
Re: 67 Camaro disc brake upgrade/9 inch rear
Have you looked at moser engineering..?
http://www.moserengineering.com/
boostin05blacksti is offline
post #3 of 7 (permalink) Old May 11th, 10, 02:30 PM Thread Starter
Eli
I checked the moser site. I am looking for the rears for the 9 inch with an e-brake and matching fronts. Also maybe a wilwood master cylinder.
Eli's67 is offline
post #4 of 7 (permalink) Old May 11th, 10, 11:59 PM
Steiner
Yeah, Moser does it. Ever since they changed their site things are hard to find. They build a 9 inch that is a direct bolt in for a first gen and make brakes for it as well as offer matching fronts. I would call them instead of buying them directly off the site. They need to know if you've got the Ford pattern or Chevy pattern on your axle ends and also if you're running original '67 location shocks or have moved to staggered shocks so they do the brackets and e-brakes correctly.
I would think that Matt's Classic Bowties or Prodigy Customs could take care of you as well.
'69 Camaro
500hp/538lbft
Steiner is offline
post #5 of 7 (permalink) Old May 12th, 10, 11:41 AM Thread Starter
Eli
Thanks ill give them a shout.
Eli's67 is offline
post #6 of 7 (permalink) Old May 12th, 10, 03:59 PM
morris
drive train specialist Ionia michigam built mine
hydromo is offline
post #7 of 7 (permalink) Old May 13th, 10, 01:49 PM
MCB
MCB Parts
We do have the 9" Wilwood kits...There are a few to choose from. Take a look at Wilwood.com and give us a call if you need any help!
MCB is offline
