Paint or not to paint Tie Rod Ends Ect. - Team Camaro Tech
post #1 of 13 (permalink) Old May 27th, 10, 03:58 PM Thread Starter
Christopher
psy4s's Avatar
I have just piled everything except my new springs in front of my Newly Powder coated Subframe. What I want to know is when my Drag link comes back from the Media Blaster, Should I paint it, or leave it natural. Would it look tacky to paint it and the tie rod ends black to protect them from the weather? The Calipers are back from being sleeved and rebuilt, and I was thinking about using the VHT Caliper paint on them also. They are Factory four piston calipers. I intend to drive my car on the road. Not use it as a trailer queen. It won’t see the snow, but it may see the rain. I am not really worried about keeping everything factory, I really want it to last better than factory. By the time it is done, I will have more in it by many times what it cost new. I am looking for opinions, and for the devils advocate. I welcome all and any opinions.
psy4s is offline
post #2 of 13 (permalink) Old May 27th, 10, 04:16 PM
Hans
Re: Paint or not to paint Tie Rod Ends Ect.
I've rattle can spray painted mine with Cast Blast to give a natural look, but to offer some protection from surface rust. I'm after a stock look and using stock parts though.
'69 RS Z28 Cortez Silver, Original Driveline, M22, 73K, Van Nuys Built, Chassis Broadcast Copy
'69 Chevelle SS396 4SP, Fathom Green, Original Engine
'06 GTO Brazen Orange, M6, 400HP LS2
sandiegoz28 is offline
post #3 of 13 (permalink) Old May 27th, 10, 07:04 PM Thread Starter
Christopher
psy4s's Avatar
Yes, I really want to finish this in a way that I will be able to take it across country to see my friends from the service. Drivability is a primary objective, with longevity being the secondary. A real close secondary.
psy4s is offline
post #4 of 13 (permalink) Old May 27th, 10, 09:44 PM
I had mine powdercoated and the center link too. Lots of people use the black as on the subframes. I decided to do mine a dark gray with a black speckle to make it look sort of like unfinished steel but won't rust. Pic not the greatest but you get the idea
68 coupe ,572,tko
Denvervet is offline
post #5 of 13 (permalink) Old May 27th, 10, 09:57 PM
I powder coated all my steering linkage with Cast Blast powder from Eastwoods. From the factory they were bare cast iron, so I wanted it to look "original" without rusting. It has a little sheen to it, but under the car and out of direct light I don't think you'll notice it. I've still got my subframe sitting on jack stands if you want to take a little drive and check it out. I may even have some of the powder left over that you can have..
buenymayor is offline
post #6 of 13 (permalink) Old May 27th, 10, 10:04 PM Thread Starter
Christopher
psy4s's Avatar
Hey I worked on a bridge in Laurel a few years ago. There was a good chicken place there near the river. I would like to see your car sometime.
psy4s is offline
post #7 of 13 (permalink) Old May 27th, 10, 10:07 PM
The Long Branch? There are lots of good chicken places in this area. Chicken and is the local staple.
post #8 of 13 (permalink) Old May 27th, 10, 10:20 PM
Send a message via AIM to RamAirDave
You're gonna want to paint them if you don't want them to rust.
Driving a #s-matching Z in the rain..... and lovin' it....
RamAirDave is offline
post #9 of 13 (permalink) Old May 28th, 10, 01:02 AM
I
Scuff, and just SEM cast blast, they do and will not see that much street abuse once installed and aligned.
musclecarking is offline
post #10 of 13 (permalink) Old May 28th, 10, 01:04 AM
I
And Wurth clear coat your plated upper contro arm shafts. just as good as your clear on your car.
post #11 of 13 (permalink) Old May 29th, 10, 09:51 PM
Where did you get your control arm bumpers? (The ones that bolt on the subframe)
Thanks!
Camaro Purgatory
67 BB Vert - in pieces
67 RS SS - in pieces (but less than before)
67 Pieces - in pieces
sci-flyer is offline
post #12 of 13 (permalink) Old May 30th, 10, 11:40 PM Thread Starter
Christopher
psy4s's Avatar
These came from an Ebay Store
4 Control Arm Bumpers 1967 67 Camaro Firebird TransAm
http://cgi.ebay.com/ebaymotors/4-Con...item2c54c40e6c
They were only $19 for the entire set.
psy4s is offline
post #13 of 13 (permalink) Old Jun 2nd, 10, 12:13 PM
Peter
I just painted my ty-rods, center link, end link, and sway bar with Eastwoods Zinc Phosphate paint, it's a little darker than Cast Blast but it looks good. I did scuff and prime the surface for better adhesion. I'll try to post a pic when I get home.
Just remember that once the engine is in, most of the components will only be partially seen, if at all. Clear coat over the components you have would probably be the quickest way out giving you rust protection.
For most of us, the cars will never see rain so rust ends up being just a minor concern, but if you plan on driving across country something should be done.
Peter
inntyme is offline
