68 brake line??? - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 17th, 10, 08:21 PM Thread Starter
Hector
68 brake line???
Well noticed that the line that goes from the front brake Block of the car to the rear axle has a hole in it.. Looked in the ground up catalog and noticed they had two listings for Front to rear brake lines... One is 2 piece setup the other 1 piece...It has the one piece now .Question is..should I just stay with the one piece or go with the two piece??? And how are these pre-bent lines?? Are they a good fit or am I better off bending my own... Thank you
Speedjester is offline
post #2 of 4 (permalink) Old Jun 17th, 10, 10:10 PM Thread Starter
Hector
Re: 68 brake line???
Anyone any thoughts
post #3 of 4 (permalink) Old Jun 17th, 10, 10:22 PM
Chris
67RSSS's Avatar
2 piece is if you have a rear proportioning valve on the side of the frame below the drivers door. Usually a/c cars had this feature. If you are running a single line than stay with it as you have no proportioning valve to tie into on your frame.
The pre bent ones are fine!
67 RSSS Van Nuys, 4th week Sept,1966
ps,tilt,headrest,spd warn,pw,am/fm,delux int,
remote mirror,rear defrost,tint glass.etc...
TKO 600 Extreme,12bolt 3:73 gears.
67RSSS is offline
post #4 of 4 (permalink) Old Jun 17th, 10, 10:25 PM
JAY
I have used prebent, but now bend all my brake, fuel, transmission lines. also bent all my vacumn lines and even put my wiring inside tubes on top of motor to help keep cleaner look! j
ps: see photobucket...Kims Nova and Mikes Nova are two of our latest
projects....j
66 SS Chevyll
67 Elcamino
68 Malibu 2dr
69 Camaro Convertible
JAYARTER is offline
