Cavert Split Mono without CalTracs - Team Camaro Tech
post #1 of 4 (permalink) Old Jun 27th, 10, 04:15 PM Thread Starter
I have an all original 327/275hp 67 Camaro with an original 3.55, 12 bolt posi rear. The car came with a power robbing power glide & I changed it over to a TKO 600. I get wheel hop really bad if I try to burn the rear tires.
Since I only have 275hp, do ya’ll think the Calvert split mono leaf springs will alleviate the wheel hop trouble without also adding the CalTracs? Thanks.
327!275hp!Convt! is offline
post #2 of 4 (permalink) Old Jun 27th, 10, 06:58 PM
Art
Re: Cavert Split Mono without CalTracs
I think you'd be better off with the Caltracs than the split monos. Any reason you don't want to run them? Any traction devices currently installed?
Artie
67 Camaro
99 T/A Daily Driver
Previous:
67 Camaro Traded for my 98
68 Camaro Street/Strip
98 Camaro Race car Best ET 9.08 @ 152 1.18 60'
Dyno sheets don't win races, see you at the track
SRGN is offline
post #3 of 4 (permalink) Old Jun 27th, 10, 08:12 PM Thread Starter
I guess just keeping the original appearance & also keeping the cost down. I have read “tons” about the J.C. Whitney 3 leaf to replace the original mono leaf springs. But then I came across some reads that weren’t as favorable concerning the wheel hop issue. Next, I’m pretty sure my mono leaf springs are original to the car & fairly worn.
post #4 of 4 (permalink) Old Jun 28th, 10, 07:57 AM
A friend of mine races his 68, runs mid 11's, has the original single leafs in, WITH Caltracs. No hope at all.
My Caltracs are sitting in the garage...just need to get the solid bushings pressed in...
They are black, so don't necessarily JUMP out at you...kind of sublte. Must less noticeable than the Lakewood bars I took off.
Hanging on the Maine Coast...moved back North
1969 RS/SS, 383, 4spd, 373s, 12bolt, FatMat, Vintage Air - Super Red, and it's my first Camaro.
Engine pics
Radiator pics
Build album
Lobstah is offline
