Removing Drum Sheild for Disc - Team Camaro Tech
post #1 of 15 (permalink) Old Jun 28th, 10, 10:00 AM Thread Starter
Ray
I have a 69 Firebird and yesterday was working towards getting things ready for the disc brake I am putting on.
I got everything off till I got to the shield for the drum brakes. I can not get the upper bolt/guide/stud (piece that aligns the drum pads and holds some of the springs on) to break loose to get the shield off.
Does anyone have any ideas?
I have been soaking it with B12 Chem-tool and WD40.
Ray
am.mscl is offline
post #2 of 15 (permalink) Old Jun 28th, 10, 10:04 AM
Re: Removing Drum Sheild for Disc
Anchor bolt. Use a longer lever.
Wear safety goggles in case your drop forged tools break.
I put a pair of ViseGrips® across the flex handle joint to prevent it from spreading and breaking.
post #3 of 15 (permalink) Old Jun 28th, 10, 11:07 AM
Vince
vincevs's Avatar
That should do it... it will come!
Vince
69 Base Coupe "The Wrecker" Project -
67 rs/SS L48 4spd Convertible -
- SOLD
vincevs is offline
post #4 of 15 (permalink) Old Jun 28th, 10, 11:56 AM Thread Starter
Ray
Thanks.
I guess I need to get a vise to put it in.
Ray
am.mscl is offline
post #5 of 15 (permalink) Old Jun 28th, 10, 12:58 PM
Vince
vincevs's Avatar
Yeah... would have been easier if it was on the car. I made the same mistake.
Vince
- SOLD
vincevs is offline
post #6 of 15 (permalink) Old Jun 28th, 10, 06:30 PM
Originally Posted by am.mscl View Post
Thanks. I guess I need to get a vise to put it in. Ray
Make sure the vise and table its bolted to is sturdy enough for the amount of torque.
Wear goggles also in case the tools break.
post #7 of 15 (permalink) Old Jun 28th, 10, 07:14 PM
Don't waste your time with WD-40...get some Kroil or PB Blaster (penetrating oil)
68 Camaro~LSx ~all motor
post #8 of 15 (permalink) Old Jun 28th, 10, 07:45 PM
Bill
Ray,
See if someone at a local shop will hit it with an impact gun .... that will take it right off
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #9 of 15 (permalink) Old Jun 28th, 10, 08:46 PM Thread Starter
Ray
Thanks guys
am.mscl is offline
post #10 of 15 (permalink) Old Jun 29th, 10, 07:43 AM
Michael
You are reusing your drum spindles for a disk brake setup?
Shouldn't you be getting new disk brake spindles?
mahunt is offline
post #11 of 15 (permalink) Old Jun 29th, 10, 07:57 AM Thread Starter
Ray
Most conversion kits use existing spindles.
am.mscl is offline
post #12 of 15 (permalink) Old Jun 29th, 10, 08:45 AM
Michael
Cool.
Well stop typing and pop that sucker off!
If worse comes to worse and you can't immobilize the spindle, just put it back on the car (don't crank on the ball joint nuts, just snug 'em up) and you should have enough leverage to back out that anchor pin.
mahunt is offline
post #13 of 15 (permalink) Old Jun 29th, 10, 03:09 PM
There's a little trick where you can modify drum spindles for disc brakes.
http://www.pozziracing.com/brakes.ht...Drums_to_Discs <--here
post #14 of 15 (permalink) Old Jun 29th, 10, 03:48 PM
Vintage 68's Avatar
Thumbs up Re: Removing Drum Sheild for Disc
Originally Posted by BillK View Post
Ray,
X2
That's what you need to get them loose
If you don't have one, most Auto parts stores rent 1/2" electric ones for a minimal charge
Make sure you use only an IMPACT type socket!
1968 Convertible
Some trucks
Vintage 68 is offline
post #15 of 15 (permalink) Old Jun 29th, 10, 06:43 PM
scblucam's Avatar
My SSBC kit came with spindles but they were VISUALLY no different from the original drum spindles. I didn't mic them.
68 302 M20 - 85 IROC Z
scblucam is offline
