'69 Small block vs big block coils - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 4th, 10, 04:23 PM Thread Starter
Dean
My original springs on the front of my '69 SS 350 are sagging a little, is there any advantage to buying the replacement big block springs rather than small block ones? I'm not into the low rider look I want it at least as high as original but much more. also what about the ones for an A/C car? I don't have A/C but maybe that would give me just a tad more hight.
440sixpack is offline
post #2 of 5 (permalink) Old Jul 4th, 10, 04:46 PM
Alan
Re: '69 Small block vs big block coils
Spring selection is a function of engine (big block vs. small block). and accessories for each car. Classic Industries has a of list springs. You make your selection based on the above mentiond parameters. It tends to cut out on the trial and error.
alan
alanrw is offline
post #3 of 5 (permalink) Old Jul 4th, 10, 06:01 PM
Tim
Be careful I got my big block springs from Classic Industries oem spec $154 that were rubbish. When i put them in they totally collapsed and the car sat on the bump stops. I ended up getting springs custom made to suit my car.
Tim
TimSS is offline
post #4 of 5 (permalink) Old Jul 4th, 10, 07:29 PM
DT
Donny
DT's Avatar
Be careful installing a heavy spring for a car that does not require it. Your ride will suffer and it may even feel like a pick up truck, meaning its too stiff. IMHO use the small block springs if you have a small block.
DT is offline
post #5 of 5 (permalink) Old Jul 5th, 10, 08:33 AM
Patrick
x2. A good quality brand also.
69RS/SS,383,10:1cr,4.10,60ft1.6sec,1/[email protected],1/[email protected],Vicjr,RPMheads,750dp, Proform main body, cam,246*-250*@.050,.510,522,1.6rr,700r4,3200stall
383 IS SOLD!
Building a 489BBC
speedfreek is offline
