Need help! Line locks not holding - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 4th, 10, 08:42 PM Thread Starter
Ok i have a 69 camaro that has had line locks on it for years with never having any problems. I changed the front brakes over to wilwood 4 piston, and changed the rear to wilwood disc also. No matter what i do it will not hold car back for burnout. Any suggestions. Thanks in advance
jd502 is offline
post #2 of 6 (permalink) Old Jul 4th, 10, 09:01 PM
Andy
Re: Need help! Line locks not holding
I found that if you hold your button THEN pump the brakes it works like a one way valve and will hold better. I had your same problem before doing this.
67 R/S convertible Nantucket blue deluxe interior orig.
67 rs-ss coupe 565BB-400turbo streetcar/racer project 1.43 60ft 9.683 140.91
2x67rs/ss is offline
post #3 of 6 (permalink) Old Jul 5th, 10, 04:44 AM
It also could be the LineLoc unit itself. Earlier models did not have stainless seat and ball, so with carbon steel, corrosion may have set in.
post #4 of 6 (permalink) Old Jul 5th, 10, 05:20 AM
Matt
Blade's Avatar
Send a message via AIM to Blade
Have you tried bleeding the brakes again?
Got to give the PEOPLE what they want!
Look....if you wanna be the best then you gotta take out the best!
1967 Prostreet Camaro
BB 431 650hp
400 Turbo Trans
Ford 9" 4:56 gears
Blade is offline
post #5 of 6 (permalink) Old Jul 5th, 10, 10:48 AM Thread Starter
yes I have tried bleeding the brakes, They worked fine before I changed brakes over. Could it need a bigger volume master cylinder due to calipers having more pistons?
jd502 is offline
post #6 of 6 (permalink) Old Jul 5th, 10, 03:16 PM
Not necessarily, try a smaller diameter M/C, it'll make more line pressure with the same force on the pedal.
