PS Box, and Pump Fittings, I have no clue.. - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 8th, 10, 04:09 PM Thread Starter
Oscar
I'm currently installing a Hydrobooster in my 68 Camaro. My question is I'm making the lines that run from the power steering box. Does any know what type of aero fitting would screw into the box, both the high pressure and low pressure side. I have the lines/hardwar to make the line, just don't know what two fittings will srew into the PS box. I purchased the AER-FBM2608 and 2609. They worked on the hydrobooster but not the stock PS box different type ends. Also the one High pressure that screws into the stock PS pump.
1. the two AER fitting for the PS Box high, and low side.
2. The AER fitting for the high pressure out on the PS pump.
Fittings 6AN
If someone could help me I could finish this swap
Thanks,
Oscar
obengston is offline
post #2 of 3 (permalink) Old Jul 9th, 10, 02:11 PM
TsX
Tim
Re: PS Box, and Pump Fittings, I have no clue..
perhaps this helps:
https://www.camaros.net/forums/showth...86#post1426286
i just hope your steering box is the original and not a newer replacement...
otherwise:
http://www.pozziracing.com/camaro_steering.htm
in the PS HOSE INFO chapter there are some aeroquip
parts with partnumbers from Earl's.
somewhere on the bottom of the page
'67 Camaro
orignal a 250 6cyl, manual 4 spd
replaced with a '69 327 by previous owner
currently swapping it to a '85 454 BB
already fixed:
HEI + electr fuel pump was connected to res wire.
SI alternator connected to external regulator
TsX is offline
post #3 of 3 (permalink) Old Jul 13th, 10, 05:42 PM Thread Starter
Oscar
Thanks for the reply sorry I haven't been on in a few days, my mom became ill so I went to visit.
