Replacement Rear Drums - Team Camaro Tech
post #1 of 32 (permalink) Old Jul 11th, 10, 03:10 PM Thread Starter
Robert
I was wondering what people are doing to replace their rear drums. I bought a set and after doing a nice neat brake job took them out of the box and realized no adjustment holes!! I have looked around and it seems everyone is selling drums w/o adjustment holes now. Do I need to pull the axles and replace the backing plate now? Just wondering what everyone is doing.
Nineteen68RS is offline
post #2 of 32 (permalink) Old Jul 11th, 10, 04:09 PM
Kurt
camsdad's Avatar
Re: Replacement Rear Drums
Going Disc.
Kurt
1969RS 14yrs into it.
383CID Lives
200R4 Trans, 3:42 Posi 12 Bolt Ready
Cold ones in the fridge. Dam, there gone. BRB
Getting closer to my goal.
camsdad is offline
post #3 of 32 (permalink) Old Jul 11th, 10, 04:11 PM
Chris
I went with discs in the rear too. Sorry...
FFRiccio is offline
post #4 of 32 (permalink) Old Jul 11th, 10, 04:44 PM
You could use a diagrinder and make your own...shouldn't be too hard
68 Camaro~LSx ~all motor
post #5 of 32 (permalink) Old Jul 11th, 10, 05:53 PM
For some reason I don't remember fist gens having an adjustment slot in the drum. Is there one in the backing plate with a rubber or metal plug in it? I could be all wrong - it's been awhile.
BPOS is offline
post #6 of 32 (permalink) Old Jul 11th, 10, 06:01 PM
Kurt
camsdad's Avatar
They do on the drum, or at least my 69 does, err ugh..wont once I change over to disc.
Kurt
383CID Lives
camsdad is offline
post #7 of 32 (permalink) Old Jul 11th, 10, 06:06 PM Thread Starter
Robert
The ones I took off had them and if the didn't not sure I would have gotten them off. I was thinking about making holes in the backing plates because I think that might be my only choice at this point. It's 8.2 non posi so it's not the rear that is staying for good but all the brakes are new now so when the time comes may want to salvage all that.
post #8 of 32 (permalink) Old Jul 11th, 10, 06:09 PM
Banned
Bethanne
Nashville Beth's Avatar
I might be misreading something here, but the adjustment slot for the star wheel is in the backing plate.
Drums are solid except for the holes for the wheel studs.
I'm sticking with drums in the rear, but I will upgrade to 9" aluminum units that came on later models.
Nashville Beth is offline
post #9 of 32 (permalink) Old Jul 11th, 10, 06:22 PM Thread Starter
Robert
Damn....that means I have the wrong backing plates. I was afraid of that.
post #10 of 32 (permalink) Old Jul 11th, 10, 07:16 PM
Chris
I removed the drums brakes from my rear end when I started the restoration. I will look through my boxes of parts to see if I still have the original backing plates.
If I do, you are more than welcome to have them.
I'll let you know if I find them.
68RS Project - taking much longer than expected
FFRiccio is offline
post #11 of 32 (permalink) Old Jul 11th, 10, 08:46 PM
Kurt
camsdad's Avatar
OK, I took a look at mine. Late 68 build 12 bolt posi. The rear drum brakes have the adjustment slot in the hub. Rubber plug removed to view slot.
Interestingly, there is a perforation for another access slot next to a balance weight welded to the hub along with 2 other larger holes and 1 in the shape of the letter C along with a part # 3841177 and code W-2X.
No adjustment slot on the backing plate.
Kurt
383CID Lives
camsdad is offline
post #12 of 32 (permalink) Old Jul 11th, 10, 10:13 PM
Mike Petrovich
I got a performance drum kit from these guys:
http://www.praisedynobrake.com/
Great results so far.
1968 327 sport coupe. Son of original owner.
mike p is offline
post #13 of 32 (permalink) Old Jul 12th, 10, 05:57 AM
I had my drum brakes for a long time, still stock , they did have the drum adjuster slot but I never used it, I have a drum brake caliper measuring tool that I got long ago. It basically measures the inside of the drum on one side and on the other side , it gives you a measurment on what to adjust the brake shoes to, with the drum off. They slide off and on easily. I am old school. But I did just recently converto to rear disc brakes from RightStuff. They sell a kit that has everything you need, including E-brake cables.
TC # 349
zdld17 is offline
post #14 of 32 (permalink) Old Jul 12th, 10, 08:52 PM Thread Starter
Robert
I went back out tonight and checked again the backing plates don't have the hole. Guys are work recommended drilling the holes in the drums. That is a lot easier then pulling axels to get the plates off. My 68 is a late 67 build from LA maybe that matters?
post #15 of 32 (permalink) Old Jul 12th, 10, 09:09 PM
Steps
Damn you guys are a worry...hell I should know this off hand
Anyway just when out and checked my orginal Drums in storage...they are the same as the pic above...
There is no need to use adjusting holes
If you put holes in or change a drum like that you will throw it way out of balance and create even bigger headaches..dont do it
You dont need access to the star adjuster to set the drums.
Start off like 1st installing new shoes...adjust up so the drum just slides on, stomp on the brakes a few times to align/center the shoes
Pull the drum off and adjust up again so drum just slides on, maybe 1 more time.
Throw the wheels on, put the car in reverse and hit the brakes about 3 times
That it adjusted
The star adjusters are 'self adjusting' but only do it it in good clean condition and firm braking when in reverse....described in the Owners Handbook.
PS Very important...NEVER adjust rear drums up with the Hand brake adjuster AND Always back off the hand brake BEFORE adjusting rear brakes.
Steptoe is offline
