Rear 1/2" lower on the right. - Team Camaro Tech
post #1 of 5 (permalink) Old Jul 12th, 10, 06:34 PM Thread Starter
Daniel
My rear is 1/2" lower on the passenger side. Gap measured between the tire and the fender.
The question I have is, could I lift it by 1/2” by:
1) Loosing the passenger side Rear Spring Shackle bolts.
2) Lifting the car by the rear bumper, and
3) Retightening the Rear Spring Shackle bolts.
I other word, could I gain 1/2” on that side by playing with the Rear Spring Shackle?
P.S. The front is Ok on both sides.
Thanks,
Daniel.
Daniel,
1969 SS-350 Camaro, Hugger Orange
2005 Black Mustang GT
FBODY is offline
post #2 of 5 (permalink) Old Jul 12th, 10, 07:28 PM
Dustin
DVINNY's Avatar
Re: Rear 1/2 lower on the right.
I've had the leaning issue for 6 years now.
I replaced the rear springs and shocks, still leans.
I replace the front springs and shocks, still leans.
I've upgraded all the suspension and steering parts, but next weekend I am putting new subframe body mounts on the car. Hoping it will help, but I have a thread on here about it, and everyone said this is a long time problem that many have
DVINNY is offline
post #3 of 5 (permalink) Old Jul 12th, 10, 07:33 PM
Dustin
DVINNY's Avatar
Here is the link to the thread I did recently about this
https://www.camaros.net/forums/showthread.php?t=177538
DVINNY is offline
post #4 of 5 (permalink) Old Jul 13th, 10, 06:29 PM Thread Starter
Daniel
Thanks for the info DVINNY,
I replaced my body mounts last year and did not notice any change!
Good luck,
Daniel.
Daniel,
FBODY is offline
post #5 of 5 (permalink) Old Jul 14th, 10, 01:07 AM
Way more likely that the problem is in the front in my experience. First of all, make sure that the surface you're measuring things on is flat, ie. a sloped or crooked driveway won't cut it. Drive it to a flat parling lot. Measure the fronts. If they're not identical, make them so, and do a front end alignment. Camber adjustment makes a difference. Consider small coil spring spacers to accomplish it, and odds are your rear will wind up even as well. We're not talking to the 1/16th here. 1/4 inch either way is close enough in my experience.
BPOS is offline
