Wilwood 4 Wheel Disk Brake Setup - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 16th, 10, 10:45 AM Thread Starter
Tony
Hey guys, I just bought a Wilwood's 4 wheel disk brake kit for my 67 camaro and since the front rotor hubs are setup by Wilwood to use a 1/2 wheel stud, I wanted to know what you did about the rear studs? Did you just use the 7/16 factory wheel studs or did you go to 1/2 wheel studs to match the fronts?
tonyvol is offline
post #2 of 3 (permalink) Old Jul 16th, 10, 11:06 AM
Matt
Re: Wilwood 4 Wheel Disk Brake Setup
From Wilwood's assembly manual:
"Verify that the wheel axle stud size is 0.50” diameter. The Wilwood hats
utilized in these kits are drilled for 0.50” diameter wheel studs."
I would change out the studs...
Matt
zlek131 is offline
post #3 of 3 (permalink) Old Jul 16th, 10, 08:44 PM
John Doe
i was replacing my axles with new hardened ones at the same time. i would recommend this since you have to pull them anyways to get the new brackets on. the prices ranged from $200-$400 for the pair. pretty reasonable in my mind.
i then installed 1/2-20X2" screw in studs.
Bucknaked Racing is offline
