69 Camaro No Brakes - Team Camaro Tech
post #1 of 9 (permalink) Old Jul 17th, 10, 12:39 PM Thread Starter
Peter
69 Camaro No Brakes
I just replaced the front calipers on my 69 camaro. I bled both the front and rear brakes and went through 32 ounces of brake fluid and still have no brakes. I have no pedal and there is no air coming from the lines. What could it be?
Any info is appreciated.
Peter
inntyme is offline
post #2 of 9 (permalink) Old Jul 17th, 10, 12:48 PM
Re: 69 Camaro No Brakes
Did you put the L caliper on the R side and vice versa? If so, the bleeder nipples are at the bottom, and air is trapped at the top. The bleeder nipple needs to be at the top.
PS If you're just working on the fronts you don't need to bleed the rears. Separate systems.
BPOS is offline
post #3 of 9 (permalink) Old Jul 17th, 10, 01:57 PM
how about the master cly did you bleed it?
camaro9 is offline
post #4 of 9 (permalink) Old Jul 18th, 10, 07:49 AM Thread Starter
Peter
Al,
Just took a look at the calipers and the bleeders were on the bottom. Heading to the parts store now to pick up some crush washers and then am going to do the swap. I'll let you know how it turns out.
Thanks,
Peter
inntyme is offline
post #5 of 9 (permalink) Old Jul 18th, 10, 11:15 AM
That was likely your problem. If after bleeding the pedal goes to the floor don't despair. Sometimes it takes a few pumps of the pedal to move the pads up to the rotor before you get a solid pedal.
BPOS is offline
post #6 of 9 (permalink) Old Jul 18th, 10, 11:47 AM
DT
Donny
DT's Avatar
Great diagnosis Al !!!
DT is offline
post #7 of 9 (permalink) Old Jul 18th, 10, 01:59 PM
Banned
Bethanne
Nashville Beth's Avatar
The knowledge of the guys on this website never ceases to amaze me!
You guys are awesome!
Nashville Beth is offline
post #8 of 9 (permalink) Old Jul 18th, 10, 05:23 PM Thread Starter
Peter
Al,
Thanks for the help, swaped calipers and bled the brakes and all is good!!!! Except for the fact that my muncie is stuck in 3rd gear and I had to nurse the car back home from my trial run. Any quick diagnosis? I'm thinking that the shifter linkage bound somehow, but the car was shifting normal for around 5 miles of city driving.
What do you think?
Peter
inntyme is offline
post #9 of 9 (permalink) Old Jul 18th, 10, 07:28 PM
Maybe a post in the trans section? I'm an automatic guy.....
Glad your brakes work!
BPOS is offline
