can you drill a mono leaf spring - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 18th, 10, 12:07 PM Thread Starter
can u chisel off the welded on centering pin and drill a hole in a mono leaf spring.
i need to bolt on a 4 degree shim and install a new center bolt.
note the centering pin is on the bottom of the spring and the shim needs to be bolted on the top of the spring.
Shameless is offline
post #2 of 3 (permalink) Old Jul 18th, 10, 12:18 PM
Re: can you drill a mono leaf spring
Good luck on that! I have a chunk of an old monoleaf I was going to drill a hole through and use as a spacer - couldn't even scratch it with a good quality bit. The spring steel is heat tempered and is tough as hell. I have a friend who works in a spring shop - he told me that they use a machine that that punches the holes.
BPOS is offline
post #3 of 3 (permalink) Old Jul 19th, 10, 09:29 AM
mbrekke's Avatar
I wouldn't drill a hole. They are really thick in the middle. Not like a normal spring with a stack of thinner leaves. They're pretty brittle too. I would think it would eventually break at the point of the hole.
68 327 4-speed 3.42 posi and a sunroof
best so far... 13.25 at 106mph
78 Firebird 350/T350 3.23 posi
65 Mustang convert. 6 cyl. 3-speed
66 Mustang coupe 6 cyl. auto
80 Chevy C10 406 4-speed
mbrekke is offline
