problem installing QA1 springs on 69 camaro - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 22nd, 10, 12:59 PM Thread Starter
Ok, so i have a 69 Camaro that I am having being modified into a PT car. Mechanic is having troubles installing the QA1 shock on my 69 camaro. He's having problem with fitting the top of spring into the stock frame. it should fit nice an snug into the groove where the top of spring is suppose to sit. Instead, the top of spring cannot fit into the groove because the top of spring is too large in diameter. When installing these shocks/springs should the frame be cut and modified so the springs fit? or is there a smaller diameter QA1 spring that fits nice and snug?
danksta1969 is offline
post #2 of 4 (permalink) Old Jul 23rd, 10, 11:28 AM
steve
Re: problem installing QA1 springs on 69 camaro
I ordered the stock Z28 replacment springs for a SB w/AC and they fit nicely into the groove. When you mention the DIA is to big is it the overall diameter of the spring or the DAI of the wire itself ? I certainly woul dnot start cutting away on the frame to make it fit.
sflippen is offline
post #3 of 4 (permalink) Old Jul 23rd, 10, 11:32 AM
Stock Z with A/C, very rare car.
john68 is offline
post #4 of 4 (permalink) Old Jul 23rd, 10, 11:53 AM
What QA1 part number are you trying to install? Tough to say if you have the right one when you don't give all the info...
Eric
Eric Kammerer is offline
