March PS Pump Leaking - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 23rd, 10, 11:09 AM Thread Starter
Tony
Hey Guys;
I just installed a brand new March PS pump on my 302. I hooked it up, filled the fluid, bled it well (got a bunch of air to come out), took the car for a drive and...pump makes a lot of noise and is leaking fluid down the front crossmember and onto the floor. I checked my hose connections 3 times, even took them off once and reinstalled. Still leaking. It's difficult to tell where it is leaking from, but the front of the pump appears to be dry. The fluid runs down the pump from somewhere and when I wipe my hand across the bottom of the pump, it's wet there. The steering box connections are dry. I think its time to call Summit and let them know I have a faulty pump? Any suggestions? Thanks very much!
Tony's '69 -
69RS/Z28 is offline
post #2 of 3 (permalink) Old Jul 23rd, 10, 11:52 AM
Robert
Re: March PS Pump Leaking
If you overfill a ps pump it'll keep chucking fluid out the fill cap.
1stGenLvr is offline
post #3 of 3 (permalink) Old Jul 23rd, 10, 11:58 AM Thread Starter
Tony
Thanks Robert - per March instructions, the fluid level is to be just visible inside the filler neck. I didn't fill it above that.
Tony's '69 -
69RS/Z28 is offline
